Understanding timing report
Good morning!
so I got a Gruen Precision with a 510 movement, the simplest with the sub second dial, my James Bond watch, lol.  Well, it was running good the first couple days, seemed to be less than a minute off after two days, so I was pretty happy, and the movement looks really clean so I thought I might get away without having it serviced right away.
then it stopped.  I found that If I bumped it again it might run for a few seconds before stopping again.  So this morning I had a little time so I broke it open and popped the movement out.  I played with the balance wheel a bit, turning it a little and letting it go.  It would run for a few seconds and stop again.  I did this a few times then it started running 30 seconds at a time, a few more times and it has kept going an hour now.  I timed it and this is the output, dial down.  I didn’t try any other positions.  It never would give a rate, which seemed weird, I haven’t had this happen before.  The error would hang right around 0-0.2ms for long periods before jumping up to 4.3ms and back down.  Any ideas on what might be wrong?  Does this look like a case of just needing some oil or something is probably broke sort of thing?
Poor lubrication can stop a watch. Would need dismantling and inspecting to say if anything needs more work other than lubrication. Perfectly fine running watches can produce these kinds of traces at very low amplitudes. Beat error and amplitude reading mean nothing with a trace like that.
Where you bought from? Maybe it was is some place where not much attention is paid to shop cleanliness, so a fiber can eventually find its way around a pivot or in between cogs. If you don't feel ready to re-service it yourself then you'll have to return it or pay a professional.
That looks like the timegrapher app. It’s garbage! Get a real timegrapher. But your beat error is way off I cant go off these results because of the app, but if this were a reading on an actual timegrapher i would say you need a service and a beat adjustment. There is no way your beat error would be .2MS with that reading.
You keep beating that drum of "real timegrapher" without any basis and usefulness to the OP. The correct answer was given above already:
As you read my post i pretty much said the same thing. its not a drum iam beating. Ive seen too many people skimping out paying $12 for a crappy app when they could save themselves stress and confusion with a decent timegrapher 1000 for $150. This way they will get an accurate trace and beat error and amplitude will mean something. Its obvious this watch clearly has issues an needs attention a timegrapher is not needed to determine that but the OPs entire post was based on “timegrapher results” if you read the title to the post. So please explain in further detail how are you think me telling the OP to get a better timegrapher doesn’t help him. Maybe not here and now with this watch but in the future with other watches he may have.
  • Confused 1
Needs a service.  Sounds like dried oil specially on fork pallets.
If you have removed the dial. Dunk the movement in lighter fluid , swirl the container, for a min or two. Take out the container and without delay get the balance wheel turning by blowing a puffer tangential to the rim of balance wheel, easy on hairspring, once the fluid has vaporised off of the hairspring it takes off running and for hrs.  This to show the issue is one of dried lubricant and a good service is in the order.
Regards joe.
It is, but the beat error wasn’t 0.2MS, it was averaging 1.3MS (iirc, just looked and already forgot lol ).
when I popped the case back off I found that the balance spring must have been going, it was moved all over to one side, and after running a few cycles it actually broke while I was watching it.
I’ve got 35 junk 15 and 17J movements to practice doing cleanings, tearing down, lubing and reassembling.  Which is what I’ve been doing the past week.  I’ve done 5 so far so I’m not rushing.
I keep having problems getting the pallet fork and balance spring back together right so I’m figuring that out now.  So far I’ve managed to get everything else put back right, but I’ve taken extensive photos and videos of each step so I don’t miss anything, lol.  I’ll probably still end up sending that Gruen in though, I don’t think I’ll want to wait 6-12 months before being able to wear it working lol.
When you say pallet fork and balance spring back together, do you mean the roller jewel seated correctly in the pallet fork? If so i actually just replied to a post on this exact process.
Yeah, that’s it, sorry my terminology comes from books published in the 60s, YouTube, is then half remembered and half understood before being garbled by my brain on the way out.  My fingers offer little resistance to my errors too, I don’t trust them lol
It takes time, when i first started my hands would shake, part of that is because when your are new at it you are concentrating too hard on not loosing a screw or screwing up hairspring etc you dont even realize your not breathing right or even at all, depriving yourself of carbon dioxide which makes you feel nervous. Next thing you know your gripping screws to hard and pinging them across the room, Over time you will gain confidence, learn to relax, and not worry too much and then your hands and  fingers will be steady as a rock. Breathing properly helps as well as feeling relaxed, watchmaking should not be practiced under duress. But in time you will actually be able to use it to manage your stress and it will actually start to help you relax even when you are already stressed because you will get into that mind set before starting to work. Kinda like some people make model airplanes to relief stress. Iam a very impatient person with a hot temper, but Iam a totally different person with a pair of tweezers in my hand. That’s why my wife doesn’t complain i spend so much time on the hobby lol.
Edited by saswatch88
I actually meant their inability to prevent from from typing nonsense, but they’re not the most steady.  Even under normal circumstances my hands shake noticeably, they actually had me get an mri when I was in high school because of it.  They’re not as bad as they used to be, but it took a lot of time to learn to draw nice straight lines (I draw comics in my spare time, well, I ink comics, I usually work with a penciller).  This will be much the same.  As long as I stick with it and don’t give up I’ll figure it out.  I was super excited when I managed to get one working again.  Now I just have to figure out how to do that reliably.
Just like you Iam an artist as well, went to college for it and its my main profession. totally get you on the straight lines problem, i also did tattoos since i was 15 which helped since making a straight line with a machine that weighs 2 lbs and is vibrating makes a pencil or paintbrush a walk in the park. BUT I  have to say since i started watch repair i could almost be a brain surgeon.
    • This is a very sad day for the industry.. For most of us being amateurs the cost of replacing parts for ETA,s etc will be beyond affordability for the customers.   see full statement below   We have now received the decision from Judge Michael Green on whether or not the High Court has jurisdiction to hear our claim against Swatch, and sadly it is not the decision we had hoped for.   As we have pointed out in previous news items (see below),the rules that Judge Green had to apply strictly prevented him from examining in any way how the Swiss Court arrived at its verdict, even if it is blatantly obvious that the verdict is wrong.   As Swatch’s lawyer was summing up in the last few minutes oft he hearing, the Judge twice pinned him asking if it was alright if, as a result of the Swiss verdict, consumers had to pay 50% more for their watch repairs. After some stumbling, their lawyer’s reply was “Yes”, so  I am quite sure that Judge Green left his court fully aware that the Swiss verdict does not reflect the norms of British Competition Law. However, the rules simply do not allow him to take that simple fact into account.   Judge Green noted that our two arguments relating firstly to British Competition Law now being different from that of the EU, and secondly to the contention that the legality of the Authorised Service Networks has not been tested, had both been mentioned in the Swiss verdict. Because they had been mentioned, he felt that to allow us to argue them again would constitute re examining the Swiss case, and could not be allowed.   As to our claim that we were denied our right to be heard because our evidence was not considered, our lawyers had argued that the evidence we provided could not have been looked at because had the Swiss Court done so, it could not have reached the conclusion that it did. In his verdict, Judge Green highlighted general statements in the Swiss verdict that evidence had been looked at, and acknowledged the arguments we made to him, but again he considered that this was re-examining the Swiss verdict, and could not be permitted.   Our case has attracted considerable interest within the Legal community, and within minutes of the decision being made public we were approached for comment by one of the largest subscription news services, Global Competition Review. They asked us two very pertinent questions, and I reproduce them for you below along with our responses, as they neatly summarise the consequences arising from our case.   What are the key takeaways?   Enormous damage has been done to the fundamentals of UK and European Competition Law by the Swiss courts. It has always been the case that the effect on consumers and competition has to be considered in any decision making, but we now have a ruling that states even monopolists can remove wholesale markets from the supply chain without any consumer benefit based justification. Those entities looking to subvert Competition Law and exploit consumers for their own benefit will be looking at this very carefully.   Has the court made the wrong decision? If so, will you appeal?   The issue lies not with the High Court, but rather with cross border jurisdiction treaties that have no requirement in them for foreign jurisdictions applying UK law to take account of the Ratio Legis [a legal term for the fundamental reasoning why the law was written] of that law, and have no remedy within them for UK Courts to overcome decisions that clearly do not.    After eight years of work, and a very considerable sum in legal costs, I can not begin to tell you how disappointed I am at this outcome. For the time being, there is no further route through the British Courts that Cousins can follow. However, I promised that we would fight to the end, and that promise stands.   The UK is no longer part of the Lugano Convention, whose rules Judge Green has applied, and as yet nothing permanent has replaced it. The political tide turned against repair prevention by restricting supply of spare parts some time ago, and our efforts on behalf of the Watch Repair industry have resulted in high level contacts within several Government Departments. You can be sure that we will keep working to overcome this unjust situation that we now all find ourselves in.    I will keep you advised.   Kind regards   Anthony
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw Darwin’s theory of evolution has not been proven to be absolutely.  😀
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
