Replacing tips on handsetting tools?
Ishima
Hi everyone.
As some will know most quality hand setting press fit tools will have replacement tips available. I have a set of bergeon hand fitting tools that, one clumsy moment after another have had enough tips snap to render the set useless.
Id like to replace the tips but I cant even figure out how youre supposed to remove what remains of the old tips.
Even on ones with plenty of plastic to grip theyre in there far too tightly and im stumped.
Anyone have experience here?
Theyre super tight, trying to grip where there is still plastic left the plastic gives way/crumbles before the tip starts to pull out.
I dont think they have a thread but that actually might be worth trying. Thanks
Edited by Ishima
Hi everyone, so ive managed to fit the new tips now.
I had to be extremely rough in getting the old tips out, basically destroy them as much as possible and dig out what remained.
The new tips went in with reasonable friction so there was no issue there. Thanks for your help.
Edited by Ishima
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
