Pressing flat mineral glass with Robur press.
Flubber
Hello,
I have ordered a robur glass press and dies (expensive) and my first project is to change the mineral glass of my nephew's watch. However, when I watched Mark's videos on changing glass he used a flat die but as far as I can tell there are no flat dies in the robur die set. My question is if I can still use the press with the supplied dies or use some sort of plate between the die and the glass without breaking anything, neither the watch nor the die ?
    • Snap! I recently finished my Gruen 510 movement - though the case for mine is in a rather sad state; I'm going to try re-plating it (in nickel, it's not a gold one).   Re. the screws, I got a few of the one gram mixed batches from ebay. I've only needed a couple of screws for things so far, both rare, minuscule types - but both in the mix, after enough time sorting through them! The ones such as normal bridge screws are quite common in those lots.
