Doreen
Helvetia Pilot watch caliber 51-10
30 minutes ago, Nucejoe said:
To stay on the safe side, I try to put together an assortment. Regards joe
Very much appreciated. If you happen to know  from were I can order (or perhaps you have some washers weights for the balance as well) please let me know. It seams to me that this balance wheel will need some extra weights too since the hairspring got broken and now is shorter a little bit. For know is running pretty well with the rodico on the balance. Of course this is not a permanent solution.
Share this post
Link to post
I managed to find those timing washers online and I’m wondering base on my balance screws thread measurements (thread  diameter 0.30mm; 0.32mm) if those are going to be a good fit in my case? Or perhaps I need something else?
https://timesavers.com/i-24049183-timing-washer-144-piece-assortmnet.html
Any suggestions are very much appreciated.
Share this post
Link to post
Hi Doreen,
Sorry for late reply. Here is the website of Andy http://www.timeworldservices.co.uk/ I have a bought a few watches of him and he has serviced and repaired a few of my most delicate watches. Service level is top notch and cost is reasonable.
I am not familiar with the movement designations you refer to but the movement layout is rather specific so it is easily identified from pictures with form of bridges and the unique anti shock spring. My watch is a German Flieger from 1935-1938.  I Have also found  DH watches with the same movement and civil watches similar to the DH. Of course there might be differences that I was unaware of. I am sure Andy can sort all this for you with his knowledge.
I enclose a picture of my watch for reference and I hope this helps you.
Regards
Share this post
Link to post
2 hours ago, Kvisten said:
Hi Doreen,
Regards
Thank you for getting back with me. I will definitely contact him for this matter.
Beautiful watch you have there, it’s a early flieger; I really like it.
Mine is very similar with yours; it’s a flieger German watch from WW2 1941-42image.thumb.jpg.835e2b069333a99de5b90717516f2dbb.jpg
Edited by Doreen
Share this post
Link to post
It is a brilliant watch you have there. I hope you get is sorted. I fell in love with the propeller dial the first time I saw one :)
Share this post
Link to post
I’ve purchased some timing washers and a posing tool since I have to add weight to the balance and I need to put the balance in poise too.
I've been looking to purchase a used poising tool and I come down to Levin and Bergeon
Since Bergeon tools are pretty expensive for my budget I end it up purchasing the Levin poising tool with the bubble leveler incorporate.
I know the jewels have to be perfect with no chips and the tool has to be perfect level to the working table. My dilemma is; I believe the two jewels jaws are not quite parallel to each other. One end is slightly more open (the jaws are more open then in the opposite end). I don’t know if this problem will affect negative the exact working purposes (poise)of this tool or not? On my unprofessionally opinion I believe it will. I also ordered  a few small leveler bubble since I didn’t have anything that small on hands, just to see if the two jewels are perfect leveler between  each other...I’m still waiting for them to arrive so I can check on that.m too.
I don’t believe the two jewels jaws can be adjusted between them in case they are not perfect level? Any suggestions about this?
Share this post
Link to post
Those Levin poising tools are among the best ever made, I would be surprised if the jaws were misaligned- though in 60 years of handling who knows. If they are good in the vertical plane then a slight misalignment face to face really doesn't matter. Use the two moveable feet to get the integral bubble level on, and you want to swipe the jaw edges with clean pithwood before use. I usually have the jaws slightly closed so that the pivots almost rest on their conical portion, then open up a bit once the balance is in place. If the balance has a serious poise issue it will roll toward the heavy spot- you want to stop it every quarter turn or so and see if it rests (it will just keep spinning from momentum often if you don't intervene). Once it's close, manually move it in 90 degree increments and see that it stays put. Once it does you're poised.
Share this post
Link to post
On 12/31/2019 at 8:01 PM, Doreen said:
I will try to see if I manage to find the right screw for this balance.
Happy New Year 2020 to all of you.
Hi @Doreen , Small assortment I believe six so far, of balance screws is ready. Drop me your address please.   Regards joe
Share this post
Link to post
Many thanks for your advice.
Right now, without being able to check to see if the two jewels are perfect lever between them... my balance wheel after I added a few weights washers and going back and forward many times it seams to stop on different spots now every time. Before that it stopped on the same heavy spot every time. I’m wondering if stops on different spots, is that means the balance is poised now? Also It will take a long time for the balance to stop. If I let it go it will spin down from the poising tool. I will definitely try out your suggestions with the 90 degree increments this afternoon as well.
I tried to used a different balance wheel just to compare them and the second one it was bouncing back and forth fort a few time and then it will stop on the same heavy spot side without spinning  to much. This one is definitely out of poise.
Share this post
Link to post
Thank you very much for all your efforts on finding the screws for me. I did managed to find some screws for my balance; from a old Longines movement. I had to add more weight to it but I managed to solve that problem.
Anyway if you really don’t need the screws I will be happy to have them. Please let me know how much do I owe you for that? Many thanks again
Share this post
Link to post
If everything is clean and level you should be able to stop the balance anywhere you want, at the same time, if you set it in motion it will go and go and go. If it stops abruptly it's a sign you're not clean.
Share this post
Link to post
We got this semi official little arrangement on the forum, to pass on spare parts, from which I have already benefited. If you like to join, you may find spare parts in your bag of tricks that other members are looking for.
This pass it on program, in its true spirit, is helpful and a chance for friends to share.
 Best wishes.  Joe.
Share this post
Link to post
 Best wishes.  Joe.
This is a great idea. I will definitely like to participate on this too.
Share this post
Link to post
48 minutes ago, Nucejoe said:
PM me your address please.
Joe
Im really  grateful that you are offering to help me out with the screws, however I’m not filling confortable to post my personal address online.
As I mentioned before I have already found some screws that are a good match for my balance. Please save those parts maybe to help somebody else. I really appreciate your help and advice. Many thanks and I hope you are not going to be offended in anyway.
kind regards
Doreen
Share this post
Link to post
6 hours ago, Doreen said:
Joe
kind regards
Doreen
No offence taken.    Best wishes
Share this post
Link to post
I tried the balance wheel again on the poising tool by manually move it in 90 degree increments, as you advise me, and it stays  still once I stop it from moving.  It will rest on that specific spot. If I gently give it a push again it will run and run and run. It seams that I manage to poise the balance?
I also noticed one of the pivots is not quite perfect; it has a very small tiny groove on the end. That probably will affect the quality of the poise too, I asume.
What I don’t understand is after I perfectly adjust the poise tool so it will be perfect level on the working table the balance wheel seems to always runs towards the same end every time until it’s fall down. If I pushed it on the opposite direction, it would run quite a long distance but then it will very, very, slowly stop. Any suggestions?
Edited by Doreen
Share this post
Link to post
Even the slightest out of level condition will influence the balance; but "pretty level" is fine. The level built in to the tool was accurate when it was made, but things could have shifted over time. If you want it really on, find the position where it behaves as level and mark a point on the level vial with a black marker so you know where the bubble should be.
It does sound like you've poised it- good job!
Share this post
Link to post
Thank you very much for all your good advices and help.
Im so happy, It seems that I finally managed to poise my first balance wheel. That will call for a toast tonight. I never thought  I will be able to go so far with this (on the watch repair field) especially that my hands are not quite steady. My biggest problem is when it comes to adjust the hairspring coils. You really need to have very steady hands otherwise everything can be ruined in a blink of an eye.
As for the Levin tool level bubble; I’m still waiting for the high precision level bubbles that I order to arrive. Than I will check the original bubble leveler from the tool against the new one and see if I will have any differences between them. If I found any difference between them I will probably replace the original one with the new one or maybe I will attach the new one one to the tool against the old one. Will see...
Share this post
Link to post
Loading...
  • Similar Content
    • By AdamC
      Hello,
      I'm working on a vintage pin set movement. I was really hoping to service the working movement and obtain the missing winding stem but cannot find any symbols or caliber number clues on the movement plates or bridges. Yes, there are numbers but these look like serial numbers. I have added some photos if anybody can help. Having looked at this site, I found my nearest clue from the photo id of this Helvetia General Borgel movement but of course still no exact caliber id. My movement measures 25.35mm (approx 11.25''').
      Any ideas?
      Thanks
    • By PhilB
      Hello Guys
      I though I'd introduce myself to the forum.
      I was looking for a hobby for the winter months that involved fixing/re-conditioning things and decided I'd like to give watches a try. The fact it doesn't take up much space and create a mess is a bonus.
      I'm not sure if I've chosen the right watch to start off with, but it's a Helvetia (working).
      My knowledge consists of absolutely zero information about watches, so I have a steep learning curve ahead of me.
      My plan, unless advised otherwise, is to strip down and build it back up. If it still runs, i'll be very proud with myself.
      Any thoughts on this watch as a place to learn watch repair?
    • I think i "screwed" up. I screwed back the quarter screws as well and I don't think they are quarter screws. Plan B is to screw them back in and turn out the meantime screws one or two more turns...add washers if I have more than 3 turns as recommended and see where I get. BTW, I'm doing this with the balance in place but hold it carefully with tweezers. Any issue there? Sent from my GT-N5110 using Tapatalk
    • The jewel hole seems to be cracked....this is your problem Sent from my GT-N5110 using Tapatalk
    • It is a man's man solution to repair....should have used duct tape a la Red Green Sent from my GT-N5110 using Tapatalk
    • "William Goffe, Watchmaker and Chronometer maker to his Majesty’s Packets, is listed in as working at The Moor, Falmouth c. 1800 in Cornish Clocks and Clockmakers [H. Miles Brown]. He is listed as a London maker in Baillie’s Watchmakers and Clockmakers of the World. " Source -> https://lapada.org/art-and-antiques/domestic-regulator-longcase-clock-by-goffe-falmouth/ Keep us posted with your progress.
    • Hmm tricky.. they both look as though the hairspring may not be entirely flat, but the pictures are not that clear. The one that doesn't run, does the balance swing freely, and does the fork move back and forth (albeit for a short period before it stops)? Try that first, don't oil just yet, and lets see if they actually run.
