Omega Watch Bracelet
Can anyone help me to to identify an Omega Watch Bracelet please.
It is a genuine item with all the correct markings and I would like to find out the model of watch it is intended to fit.
Stainless steel, flat links at the sides and beads of rice running down the middle
The ends are flat and made to suit lugs with a 20mm gap.
The No. on the clasp is 1173 + an oval with No.12 in
The ends which fit within the lugs are marked 718
It is new and unused, never fitted to a watch and I want to sell it ( not here )
I'm sure it could be worth a lot of money if I could identify the model it is supposed to fit.
Any ideas would be very helpful, thanks a lot and a Merry Christmas to everyone
The 1173 and 718 numbers are important here, I believe, not sure about "no. 12".
1173 and 718 will tell someone what watch/watches the bracelet will fit. (it'll fit on more watches but we're talking here about the watch that it's supposed to fit in terms of originality)
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
