Adventures in Pad Printing
Hey guys, I have been working on a project to make my own watch dials over the past few months. I thought I would share my progress with you thus far. It has been an awfully expensive endeavour, and I have yet to reach a final dial but the work is well underway. I have purchased a pad printing machine, speciality inks and pads as well as a custom engraved cliche of my design. Now I’m putting it all together, I have been practing printing on plastic watch crystals, until I have my silver dials complete to print on. Let me know if you have any questions.
Cheers
  • Like 10
That's brilliant!
I bought a pad printer a while back, which unfortunately haven't done anything with yet.
Could you tell me specifically, what inks are you using and where did you get them from? Which pad out of the three you have posted work the best for the acrylic blank you have been using? Where did you get the acid etched metal plate made up and how much did that cost? Did you design the dial yourself, because it looks really good? What software did you use, if you did?
I know that's a lot of questions, but this has given me a kick start to be enthused about doing this myself, rather than my pad printer collecting dust
Thanks so much for your post as well Liam!
Thanks Jon, I’m glad someone is intrigued by what I have been doing.
I am using ink made by Berlac, several Swiss firms sell it, including Bergeron. It’s expensive but I didn’t want to experiment with other inks.
I have used all three pads, however the one in the center has produced the best results thus far.
I got the plate etched for me by a US firm, but any pad printing supply company should be able to etch steel.  Mine cost about $500 Canadian dollars.
I did design the dial myself, I am going for a vintage vibe. Thanks for the compliments! I used adobe illustrator to design it as it is software I am familiar with. Photoshop or any graphics program can do the trick.
It has been a fun adventure thus far, but I am excited to have a watch with my own dial. Nothing gives me more respect for the watchmakers in Switzerland then seeing all the effort that goes into such small aspects of a watch.
Excellent results.
What resolution of detail can you produce?
What depth do they etch the steel?
Have you considered etching your own plates?
It shouldn't be too much more complicated than etching copper clad PCBs, which are fairly easy to do in the home workshop.
https://www.wikihow.com/Acid-Etch-Steel
I had planned a few experiments using basic materials, but like a lot of projects, the missing material was spare time.
I will need to take another look into this.
Hi LiamB ... Congratulations !!!
Your printing on crystal is wonderful and you an impressive work there ...
I've been trying silk-printing with so so results so I really want to try pad-printing, so may I ask you where you got your pad printer ?
It looks like it's a vintage one but if not would you share a link to where you bought it ?
Envoyé de mon moto g(7) power en utilisant Tapatalk
I thought about making the steel cliche myself at home however I didn’t want the mess and adittinal difficulty of doing it myself when a professional could provide me with an excellent cliche.  As for what detail it can produce, and the depth of the etch; I cannot answer that question. However I can say that the detail is very high. (Just another reason to get it made by a professional)
I wish I could share a link to where I purchased this machine, however I bought it on eBay. The owner claimed to have purchased it from a sale of old equipment from a Longines production facility in Switzerland. They are difficult machines find, and I was lucky to find such a high quality model. One of my main reasons in purchasing it was seeing the same machine used in some watchmaking pictures and videos of brands like Patek Phillippe.
My machine is made by Schmid Machines, (http://www.schmid-machines.ch/web/index.php
and yes they sell for around $2000USD used. Schmid sells the new machines for around $5000CHF. Definitely not cheap :mellow:
As for toptimes question, I am machining the dial to fit a particular case, and a specific caliber, although they can easily be made to fit most center seconds caliber, however the limiting factor is obviously the size of image on the cliche.
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
    • I'm going to give this a try today/tomorrow on my UTC33/Seiko 66, thanks!
