  • 0
sjhilbel
Cleaning watch parts
Question
12 answers to this question
  • 0
Or you can, for starters, go the manual way and use lighter fluid/naptha (which is what most people recommend, especially for beginner work). Could also use some water and diswashing soap I guess. Perhaps some isopropyl for final rinsing.... ?
Careful what you clean and how. The palet fork needs a different approach. Ultrasonic can make the rubis come off.
Share this post
Link to post
  • 0
Many, many topics on the same subject, it's always better to search before asking.
Lighter fluid contains wax, perfume, and other contaminants. It is made to burn well, not to clean well. It was recommendable decades ago when no practical alternatives existed. Use instead petroleum ether, which is pure and leaves no residue. It is cheap and available online.
Share this post
Link to post
  • 0
Ronsonol lighter fluid is so safe you can clean watch hairsprings in it. It doesn't dissolve  shellac, so the pallet stones are save and so are the impulse pins on the balance. You can leave parts in Ronsonol for days, providing you have the parts in jar that has a screw fitting lid. The fluid evaporates very quick.
Share this post
Link to post
  • 0
First and foremost, I'm sorry for not searching for the subject. It's been ages since I've been on any forum so I am very rusty. Lesson learned.
Many thanks for all the help! These are all very doable starts. Getting a ultrasonic cleaner seems doable, but I appreciate the notes about Ronsonol and petroleum ether. The jewels have been my biggest concern so these two cleaning methods will make first cleanings a bit more palatable. Thank you, all!
Share this post
Link to post
  • 0
Probably everyone have their own workflow for cleaning watch parts, but the products used for beginners (like me) are usually very similar. Here's a video of a guy I follow and I've learn a lot from, talking about how he used to do it (I think he has improved their method and tools), my workflow as an amateur is very similar, although I use naptha instead of Renata which is not availble in my country I think.
BTW, I add amonia to the water/detergent bath, and add a rinse with distilled water after this first bath.
Also, you need to inspect the parts after the cleaning to remove any remaining oil basically on the jewels. With this and a bit of practice you can get very good results.
Edited by aac58
Share this post
Link to post
  • 0
I use naphtha which is essentially lighter fluid.  Get some sealed glass jars from Amazon (Small ones work very well).  You can peg jewels with toothpick/cocktail sticks until you buy some peg wood.  Pith the pivots before and after the first cleaning cycle ( I use three jars successively).  Remember it is flammable and don't breath the vapor from the cleaners any more than necessary.  Naphtha will dissolve many plastics, so be careful or they will contaminate your cleaning jars and potentially damage any plastic parts (Seiko).
Good luck and have fun.
RMD
Share this post
Link to post
  • 0
depending upon your location and how enthusiastic you will be on cleaning watches it's interesting what can be purchased from Amazon. so lots of ultrasonic machines and cleaning fluids. the only problem is there available in 1 gallon containers and cleaning a few watches here and there that gallon will last you a lifetime. the only problem with a gallon of the cleaning fluid is it seems to go bad after a number of years the rinse appears to be stable.
so the link below is for the rinse which in real life is still a cleaning product. Other than the quantity it's actually designed for cleaning watches versus all the other recommendations above even though they're all in the similar category.
 https://www.amazon.com/Ultrasonic-Watch-Rinsing-Solution-Gallon/dp/B01LORNEDC
Share this post
Link to post
Answer this question...
Loading...
    • I've just moved house, and of the hundreds of items in the workshop it seems the power supply for my Cousins' LED desk lamp has gone missing. This one, discussed here before.  Could anyone with the same lamp tell me what the power supply looks like? Colour, type (wall-wart or in-line?), and specs, in case I have to replace it. Before realizing that I was using a 12V supply that was actually for my watch timer, I was already debugging the thing with my oscilloscope. I wasn't able to find anything wrong using a benchtop PSU at 18V, *except* for the main diode (that feeds the MCU via a 7805) being the wrong way around. My electronics education from 25 years ago is failing me in explaining how this could ever have worked in the first place, lol.
    • As said above, these can be a really tight fit, in some cases they are friction fitted right where they seat, on others they are tight all the way along the shaft. I use levers like in the photo (these are Bergeon, about 10" long) to unseat it, then if it's still tight I use the little puller to coax it off the rest of the way.   Getting it off is one thing, reseating it is another. You will need a hollow punch with a deep enough hole to pass the length of the arbor. In my case I made it, probably you can get by with a piece of brass tubing. The other issue is hand alignment after; on most clocks the hub on the minute hand can be rotated to align it with the strike, but on some there is just a square in the hand itself with no adjustment. Here you need to pay attention to the position of the cam in relation to the square so you aren't striking at 12 minutes past or something. All that said, if it's yours and you are confident it is clean and not worn, just leave it. For a customer I will remove it no matter what.   In my experience wear is more likely at the pivot that carries gathering pallet, the other cam OH mentioned first. These are usually much easier to remove.
    • As Old Hippy said if its not worn and working ok leave it on,  they are usually a tight fit and you may damage it during removal.
    • Hi   I have attached the Bolt's from my two staking sets and the fitting hope this is some help to you in finding somthing to suit.   If you can find a bolt of the same thread and a bit over long the end can be turned or filed to fit the hole in the table so that when the bolt is screwed home it locks the table and when un screwed allows it to rotate.
