Help on a Smiths Movement
Toby1
Hi
Can anyone identify this movement? It is on a Smiths round Bakelite wall clock. The one's I have googled all show the movement wound and time set from a below case knurled knob.
I believe the escapement is a Smiths EA31 but again I have not seen this configuration on a Smiths wall clock. Could it be a franken with maybe a car clock mechanism? As it stands the clock seems over wound and only ticks for a short time.
Many thanks in advance for any help. I hope to attach a couple of images.
Toby1
Thanks Vinn3,
The aim is to get it going again. But first I want to find out more about it. I have found an image of the back cover (but not cover removed ) this dates it to around 1933. However I cannot find an image of a Smiths works with the escapement in the position as shown?. There is also a possible RAF connection as pencilled on the main back plate is RAF something?
Also there is a is a small label saying 'Bakelite clock ANFDT' googling this shows it in an equation for Purchasing Document Date.
So just starting the journey to find out more.
Best
Toby1.
You beat me to it Rodabod, but atleast this one if its not genuine is atleast of the correct age.
Look closely at the dial to see if it looks like it matches the age of the rest of the clock, if it doesn't its probably not genuine.
If it is genuine it is well worth fixing as genuine sector clocks are very collectable.
Thanks all,
I am not delusional about this hence my initial wish to just find out more about the movement. I can't believe that my image is the only one on the internet showing this escapement set up in a smiths clock. I thought it would have been easy to find more out, hence joining a clock forum to consult people better qualified than me.
The whole thing seems to have some gravitas though. Firstly there seems to be some age to it. It smells fusty the back plate holding screws have never been moved for some time, and the colour fading on the segments is uniform and not printed as a faded colour. Again in internet searching I cannot find even a replica or replacement dial of this size it is 8 inch across. RAF sector clocks seem to be 14 inch upwards. There is clearly a printed hole above the '18' this would fit with smiths astral clock movements used on sector clocks. If you were replicating a face for this clock why include that?
The other issue is the hands the RAF sector clocks I have seen have a straight minute hand and a tulip hour hand. These hands would not be hard to get so why not change them if you were making a replica? Also given the age pointers was this clock worth the effort, these clocks have not always been valuable as they are today. Then there is the old pencilled RAF something on the back plate - would you really state the obvious on a reproduction? The reference to a purchasing document with the ANFDT label also on the back is also baffling.
I find it interesting I cannot find very much about this particular piece and I am very open minded as to it's authenticity.
Best
Toby1
I'm leaning to not genuine as to wind it you need to remove it from the wall to wind it, all other sector clocks I've seen you wind from the front, but the hands are correct for the 1940s as I do have a picture of a 1945 RAF clock (not a sector clock) in bakelite case that has a winding knob that pokes out the bottom so you dont need to remove it from the wall to wind
Thanks Tmuir,
You do not have to remove it from the wall to wind. The back plate when fixed to a wall hinges the whole clock from the top, this hinge assy can be seen in image 2 above. The small plate also shown in image 2 at the bottom locks this hinge for transporting?. You simply iift it up from the six o clock position to access the winder.
Also as I stated most clocks like this I have seen do have a winding knob sticking out at the bottom - this one does not.
Best
Toby1
What you have is a late R A F section clock. The older ones from the war time would have a  fusee movement. What you have is a Smiths 8 DAY movement with a platform escapement.  What gives it away is the style of the hands. They are original to the movement and are not modern. The clock might have been taken out of an old A T C hut.  This type of movement is common with smiths clocks. I have seen them in many types of cases from mantle clocks to kitchen clocks and wall clocks. The platforms varied from fully jeweled down to just the balance, they even made them with pin pallets. When it come's to cleaning pay attention to the platform for wear in the holes.
Thanks again for all replies,
As a consensus I am not skilled or knowledgeable enough to fix it. As I have said earlier it seems over wound but if  gently shaken runs for a minute or so.
So is it worth spending a hundred or so to get it properly serviced and repaired?
Also thank you for your comments oldhippy you seem on the side of genuine that would underpin my own thoughts, albeit not a control room sector clock a period piece with correct markings.nevertheless.
Toby1
Something else I trolled up although thought a late sector clock I believe towards the end of the war sector clocks had two and a half minute interval sections as aircraft got faster to plot.
I believe the five minute intervals were from 1935 to 1943.
I would say yes its worth it if it's genuine.
Just a side note, there is no such thing as 'over wound'.
If the clock is wound up and not ticking it could be as simple as its gummed up and needs cleaning to having a serious problem.
If OldHippy says its genuine I would trust what he says.
On 12/20/2019 at 12:10 PM, oldhippy said:
That's the original dial. It has staining if you look closely.  That is what I would expect to see. People write all sorts of thing on clocks, the even put sticky labels on them. If it has been through an auction house it could have been done then.
Amazing knowledge of Clocks, how you spot and interpret details and always with the relevent history.
Merry Christmas OH.
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
    • I dont think mine is. Its an idea to have them all in one place if possible, then a quick screenshot will have them saved. Unless anyone has any other ideas of how to reconnect
    • My email address is in my profile, feel free all to drop me a quick hello.
