TV shaped glass
ftwizard
This is a bale (B) shape with rounded corners (r) so would come under the Sternkreuz Br category ... which takes two further measurements of height-to-corner-starts and width-to-corner-starts to establish an idea of the corner radii.
It's surprising what nasties can be polished out of an acrylic crystal so this might be worth having a go at first.
Edited by WatchMaker
The height and width measurements are correct. They only do one that is correct in these dimensions, but the Br spec sheet lists hundreds, with some pretty small variations.
I think I may give it a go, the glasses are not that cheap though, especially for a watch like this.
I had a Bulova watch the same shape as that that no hands, Crystal and the movement was shot, after careful measuring I got a crystal that was nearly a perfect size and after a bit of sanding, buffing and polishing the sides if fitted, the ETA movement was no longer available so ended up matching it with a Miyota
Edited by Redwood
