Dial mark on Zenith
Daneel
I picked this up on Ebay and love the design, but failed to spot the mark around the 2 o'clock marker. The same issue looks to be starting at 3 o'clock. Can anyone suggest what the problem might be, and the best way to tackle it?
Link for higher resolution - http://imgur.com/a/kebkfaP
Thank you! 276bff9e25fae7a21f7901aa171fb30f.jpg&key=cc45f2aa08cedb44f34fedc9493e7f6595dcd6ab77c9c89e34be17d32c6e2fad
Sent from my SM-G970U1 using Tapatalk
Difficult to say what it might be, but it is possibly fungus or moisture reacting with the glue holding the marker to the dial.
As to what to do about it, proceed with extreme caution. Examine under high magnification, preferably a microscope, so you can see if the dial finish is damaged, or if the dark mark is only on the surface.
Thanks. Is this something I need zenith to do (that's sounding very expensive), or a capable watchmaker can handle?
Chemical recation between markers and dial? Is it a plated dial?
Send an email to Zenith and tell them that you are a long term customer but are dissapointed; can you help? etc.
Agreed. I sent them an email over the weekend, hoping for a reply early this week.
  • 4 weeks later...
Having sent the watch to Zenith, the came back to me with a repair bill of $670 for a new crown and gaskets, and another $306 for the dial (which they would not do separately from the crown replacement). Given the value of the watch, I declined to proceed and asked for the watch to be returned. I just picked up a replacement dial and am wondering if I should have a try at fitting it myself, or employ the services of a watchmaker. Does anyone have experience of replacing a dial on a Zenith Elite they can share please? Also, any ideas where to source correctly sized gaskets?
If you don't plan to do further work on watches in the future I would give it to a watchmaker. He will get all parts needed for you.
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
