Dial mark on Zenith
Daneel
I picked this up on Ebay and love the design, but failed to spot the mark around the 2 o'clock marker. The same issue looks to be starting at 3 o'clock. Can anyone suggest what the problem might be, and the best way to tackle it?
Link for higher resolution - http://imgur.com/a/kebkfaP
Thank you! 276bff9e25fae7a21f7901aa171fb30f.jpg&key=cc45f2aa08cedb44f34fedc9493e7f6595dcd6ab77c9c89e34be17d32c6e2fad
Sent from my SM-G970U1 using Tapatalk
Difficult to say what it might be, but it is possibly fungus or moisture reacting with the glue holding the marker to the dial.
As to what to do about it, proceed with extreme caution. Examine under high magnification, preferably a microscope, so you can see if the dial finish is damaged, or if the dark mark is only on the surface.
Thanks. Is this something I need zenith to do (that's sounding very expensive), or a capable watchmaker can handle?
Chemical recation between markers and dial? Is it a plated dial?
Send an email to Zenith and tell them that you are a long term customer but are dissapointed; can you help? etc.
Agreed. I sent them an email over the weekend, hoping for a reply early this week.
  • 4 weeks later...
Having sent the watch to Zenith, the came back to me with a repair bill of $670 for a new crown and gaskets, and another $306 for the dial (which they would not do separately from the crown replacement). Given the value of the watch, I declined to proceed and asked for the watch to be returned. I just picked up a replacement dial and am wondering if I should have a try at fitting it myself, or employ the services of a watchmaker. Does anyone have experience of replacing a dial on a Zenith Elite they can share please? Also, any ideas where to source correctly sized gaskets?
If you don't plan to do further work on watches in the future I would give it to a watchmaker. He will get all parts needed for you.
    • Yes, as watch repairers we never ever use force, we use percussive persuasion! 🤣
    • I have a barrel bridge arbor bearing that needs a slight reduction. I have never closed a barrel bridge arbor hole before and my staking set has a very limited number of doomed punches and most of them are too small (go through the hole) or too short to fit in the lower section of my inverto-style Boley & Leinen staking tool. So, I'm considering ordering a few doomed punches from CousinsUK. My question is what sizes I should order? Is there a rule of thumb relating to the hole diameter? I too worried that reducing the hole size would increase the end-shake. Especially as Kalle Slaap talks about end-shake at the end of the video at 7:43, but then he just glosses over it by saying "You can just gently push the material back in", which I don't get at all 🤔 Anyway, I feel a lot less worried now after having seen @mikepilk's excellent illustration. Thanks!
    • If you have access to a 3D printer, here is my design I did a few weeks ago:
    • I finished my polisher yesterday, and just tried it out. I'm surprised how easy it is to get a good result - just a couple of minutes. I thought it was going to be more difficult - a nice surprise as most things in watchmaking are harder than you expect. I bought self adhesive 3M lapping film https://www.cousinsuk.com/product/film-lapping-3m-261x266x , 9, 3 and 1 micron, and stuck it to sheets of glass. The 9 micron is course enough to remove large scratches.  I'm glad I used the M6 thumb screws as the large heads allow for small adjustments.
