"Parallel" screwdriver blade tips?
mpm235
Hello all,
"Newby"question here, I am planning to upgrade my cheapo screwdrivers, by getting a few quality ones.
I've seen that some have parallel / (hollow ground /T shaped) tips e.g Horotec.
How much better are these than the normal one? Are they are better fit for all screws, or are normal ones sometimes better? Is it worth haveng both types of tip and changing them to suit different screws?
Many thanks for any answers, Mark
I bought some Bergeon T-shaped blades to upgrade a screwdriver.  The T snapped off on the first screw.  It was a clean Seiko movement.  That ended my experiment with better.
I am getting much better at sharpening and fitting driver blades.  It is amazing how well the old fashion style works when fitted to a screw slot.
  • 4 months later...
Just a warning to anyone tempted to switch to relatively expensive parallel tip screwdriver blades.
These are intended for work on top-end movements in good condition. Attempts to free obstinate screws in older movement can result in the blade tip shearing as illustrated.
These are Horotek SS blades apparently with brittle tips.
Edited by Watcher
2 minutes ago, watchweasol said:
I think this particular topic is like watch lubrication  its open ended and can and probably will rumble on for a long time.
In general, it is so. But what the OP wrote above is absolutely correct, it's easy to understand that a V shaped tip will be more robust than a parallel one of the same size and material. And that a parallel one will grip better, for example, on a rounded profile head as commonly found in vintage parts, not limited to watch and clocks.
The one tool used the most by an horologist is the screwdriver and keeping them in good order is important for quality work. I am greedy because I have two sets of screwdrivers. One set are sharpened in the conventional chisel shape and another set are sharpened using the "horotec" MSA 01.504. sharpener. I have found that if not carful using the "Horotec"  sharpener it is very easy indeed to make the tip too thin and brittle. I therefore tend to use the conventional sharpened screwdrivers for the bigger screws and also for some vintage screws which have very narrow slots.  Another issue to be considered is the quality of the blades. The cheaper screwdrivers I have found are made of a softer metal and tend to break more readily. The pic below shows the benefits of the "horotec" shaped blade.
Oh dear it goes on.   The Clockboy 'Horotec' shaped blades are those produceb by the Horotec or Bergeon tools for sharpening hollow ground blades. My post refers to the relatively new parallel tip blades (not hollow ground) now on sale by Cousins  in three flavours - Horotec, Bergeon and Cousins. Wonderful when they fit perfectly with very little chance of jumping out and damaging the screw head but expensive when they break off by using too much force. Often the fit is so good that  the screw can be lifted out on the tip of the blade.
I just had an AHA! moment: I have found a use for all my cheap screwdrivers that are chipped, bent and who knows what else....use them to practice your screwdriver sharpening skills!
Off topic - let's restrict our discussion to these parallel tip blades964574979_paralleltips.jpg.189d119edc6d143701f7092d21a5e7fb.jpg
The same issue with the Horotec too snug a fit sometimes the screw lifts out with the blade. Looking at the parallel tip screwdrivers they are using the same concept. When working on hi end watches slips, scratches and bruised screws is really unacceptable.
Well I have a set or two of those, have to say they are quite good , but as with the traditional ones they will brake too when used in the wrong way.
Yes one might think they brake easier too but I think @jdm is right, since you have a slighly better grip one is tempted to use a slightly too small width on the screwdriver, because if it would be the other way the screw would have a smaler area in material it would break instead. Just a thought I had.
3 hours ago, jdm said:
But that depends more by the good hand of the watchmaker, not the the driver.
The tips are de-burred and polished, not something that I do every time after using the Horotec hollow-ground sharpener. Although that is a nice finishing touch - needs a microscope to appreciate the difference. But, sorry clockboy, de-burred and polished does greatly reduce the likelihood of damage. Paying Horotec, Bergeon of Cousins to do that for us is a luxury. We shall see how the market responds. As HSL says the choice of blade must be well matched to the screw head, and as I said at the start they are for top-end watches not for working on rusted old relics. Spare blades are only recently available.
Should we have a discussion on how to de-burr and polish?
    • Well done, let us know how you get on with the citizen.
    • @Neverenoughwatches Rich, I can only agree with you wholeheartedly. I spend a lot of time here learning all sorts and trying to make any little contribution to help others I can. Nothing can last forever and I wish I could do more to contribute to the forum financially and any other support I could.   Tom
    • This forum is a big part of my life. When I retired from horology many years ago due to poor health I missed what I had trained for. On here I can still do my bit in helping and advising others and have a little fun as well.
    • First thing this morning, make coffee, second, check the forum.  I would really miss the forum, not on any social media, not interested in telling the world what I had for breakfast!!! I do consider most of the regulars friends and would wonder what had happened if they stopped posting.
    • Hi all Thought I'd show my small and trying to keep under control watch collection! Apart from the Enicar all were under £12! At least if I destroy them in the process then I won't be too worse off. A few pics to start off with First of all my first attempt. A Thuya pocket watch. It was only running face down and would stop when vertical. So now it still works face down and only slows down when vertical so at least an improvement! 😄  I only have a generic watch oil at the mo so that won't help but I'm hoping to get some more appropriate oils in a couple of months for my birthday. I did have to get a crystal for it since it didn't come with one. It didn't look as though it would friction fit (and I don't have a crystal press in any case) so I glued it to the case with PVA. So far so good. Next up above are a sekonda and citizen automatic. Both non runners. Both with broken balance wheels amongst other things. I'm hopeful the citizen will start when I get the new one I ordered but the sekonda is being kept for spares and trial of new techniques. And finally the Enicar and the timemaster. Both running when I got them. I wanted to get running watches so that at least I stood a fighting chance of still having a running watch after the service! It was all going well on the Enicar until I dropped the balance wheel during reassembly...😔. Unfortunately they are quite expensive to get so for now I'll won't do anything with it but I would like to fix it at one point. The timemaster is still running (yeah!) but I managed to break a dial foot during the deassembly. First repair attempt failed so now I am looking at soldering it back on... So there we go. My initial foray into this great hobby. Thanks for sticking with this tale so far.  I'm hoping that once the balance wheel arrives for the citizen I will be able to say I bought a non runner and fixed it! So fingers crossed. Thanks for looking, Nick
