OMEGA 563
i have a 563 movement plus a 562.i am having a problem with the keyless works on the 563.there seems to be a slight difference between the two!when i came to look at the 563 i found a part which did not seem to do anything,or was in the wrong place.can anybody shed any light on this.everything on the movt.is working fine just need to keep the stem in and working.would appreciate any help.thanks B.:pulling-hair-out:
Edited by berniethebolt
Hi Bernie    the bit on the plate looks like the piece that retains the stem , running in the stem groove.     I have atteched the tech sheets for both calibers for you to identify th bit.
Omega_Omega 562.pdf 171.6 kB · 2 downloads Omega_Omega 563.pdf 556.43 kB · 2 downloads
Thanks watchweasel but I don't recognise the part on the chart! I know it's not the setting lever, that's already fitted.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
