How to Remove Armani AR-6122 Stem
Murtino
Hi  you have the hole marked push located , there should be a tag visible which you push down to release the stem. Some time you need to pull out the stem before it is visible in the window so look closely in the hole and pull the stem so the hand set position and see if it appears.
