Mainspring lubrication, manual and automatic
C07641+ not sure what the "+" is for after the last digit.
Thanks again, Dell. I'd already enjoyed your set of 8 YT videos! Photo attached.
By MartinOfPrague · Posted
All right, so here is the most likely explanation: one of the dial feet is broken off, therefore the the dial is not well centered and the short tube which is a part of the hour hand probably rubs against the edge of the dial hole. Thanks again for all the suggestions, though!
