Omega Constellation Watch Band Clasp
Zed
So my beautiful Omega Constellation watch's band clasp pusher is stuck (the thing you push on to release the clasp). I think its because the springs inside of it are either bent or broken.
I took it to a watch repair shop and they said they'll need to replace it. So I figured i'll just replace it myself so I went on ebay and found one that looks exactly like mine (i'm not going to link it because i'm not sure if i'm allowed to, please let me know if i am so i can link it). But when i looked at the pictures, i noticed that the numbers on the clasp are different to mine. I also took a picture of MY busted clasp's numbers which I have attached.
Their one says 45   HAA  and my one says  37   1BC
So my question to you is, will this new one fit on mine?
Thank you!
Regards
Z
Is it a genuine Omega bracelet that you have?
They are always numbered, mine is the same and it says 1315/282.
Not sure but I think the first part is the bracelet style and the second part is the end fitting which goes into the watch.
You have to look at the part which is against your skin to see it.
Also before you spend a load of money have a look the part you press in to release, mine has a screw so that you can get the slider out then the spring. You may be able to repair it quite simply.
Can you do some more photos which show the whole of the bracelet and both sides of the buckle.
@Alaskamick Yes, my Omega Bracelet is genuine, it has other numbers on the .. slidy bit, it sayss 1552/862  STAINLESS STEEL. I have attached 2 photos of what you asked for.
Thank you again for your help! There's a little screw right where the pusher is - is that the screw you're talking about?
Slightly different to mine but I can see the screw on the pusher which you mentioned.
I'm sure that if you take that one out then the pusher will slide out together with what ever type of spring is in there.
I you post a picture of the dis-assembled bits someone may have a suggestion how to fix it.
You can't do any harm to it.
If you can't make a spring you may be able to swop the bits from the one on Ebay.
Keep us in the picture:)
@Alaskamick So... some bad news. I tried to disassemble it using the right tools... but the screw disentegrated when i tried to unscrew it. The bit where you put the mini screwdriver (the one for watches) with the edges, one of the edges snapped so i cant turn the screwdriver anymore!
I'm devestated. Does that mean my only hopes of fixing my watch is replacing it? If so, given that the number of the one on ebay is 1551/861 versus mine that says 1552/862 ... will it fit on mine?
Regards
The buckle is a separate part from the bracelet so all that matters is the length of the tubes on the ends of it.
if they are the same size you can take the one off the bracelet you buy and fit it to your own. That will keep the watch original.
You will have to contact the seller and ask for an exact measurement.
Can you post the Ebay item no. here please.
Edited by Alaskamick
It would have been wise to stop as soon the screw didn't budge, then apply penetrating oil and wait.
It should be possible to remove it with a tool like https://www.aliexpress.com/item/4000191064648.html
The screw, likely of the grub type, can be made from regular one, cutting a new slot.
The above is watchmaker's work really. You have been just unlucky that the shop where you went initially is incompetent and greedy .
4 minutes ago, Zed said:
@jdm Sigh, that is unfortunate - i wont be returning back to that watch shop. Do you suggest I visit another and hope they will be able to replace the springs without too much of a hastle/ expense?
As I said that's work for a real watchmaker, not jeweller / mall booth shop, etc. You will have to find one and he will have to fairly charge for his time.
    • Looks that way, if it had any amount of significant jewel count it would say so on the dial.    Looks that way, if it had any amount of significant jewel count it would say so on the dial.
    • Light naptha is what you need to be looking for. The carbon to hydrogen ratio is high with heavy naptha, it doesn't evaporate as well as light naptha and is prone to leaving more residue. Try tom's suggestion of the mirror test.
    • Its a big item Michael and a lot that could go wrong with the process of getting it to its new location. I once helped install one of these units into a conservatory that i had built. It was big and bloody heavy and took six of us to get it in safely. If you have sliding doors and you need to remove the whole frame then that may or may not go well. But i would advise getting a professional in if you have little knowledge on the installation of them. The glazing of the doors could well be 6mm laminated glass which again will be heavy very heavy if the glazing units are big. The glass would also need to be set up and packed correctly to open the doors properly more so if they are unframed and the sliders are upvc. Seems a shame but if no one is biting and that may be due to having no warranty i guess the only takers might be someone that installs them for a living and knows how to repair. If its fibreglass just be careful, i sometimes have to cut fibreglass baths out and they are nasty to work with . Thick gloves are definitely recommended,  not fun picking out fibreglass spells two days later that have started to go septic. Good luck with it all matey.
    • I don’t know anything about this product, however assuming you have it if you put a drop on a mirror or piece of glass lying flat on a table and leave it to evaporate if it leaves any sort of residue it is not really suitable for watch part cleaning.   Tom
    • Well I put the spa on Gumtree (selling service) to try and sell it as it only needs a recirc pump to get it going. However, it weighs circa 250kg, so there's 4 fairly strong guys, and I would have to remove the sliding door in the room completely to be able to get it out, as well as clearing out a multitude of potted plants and the Alfresco outdoor setting to be able to get it out. Then move nearly everything in the back of the garage to be able to push it through to the front of the house. I would also need to hire furniture skates to be able to shift it around as carrying it is out of the question. Then someone would need a trailer to get it to their place as you won't get it on the back of a ute. So, the only answer is, out with the reciprocating saw and cut it all up into manageable pieces. Crying shame as it is in really good nick. I was only asking $1,500 and only got two bites, but it would only take something to go wrong with removing the sliding door etc that everything I make on the sale could go out the door on repairs etc. It would have been nice to be able to turn it into tools etc, but que sera sera. I don't know about the rest of the world, but there just seems to be very little interest from people wanting to buy things secondhand.
