Help finding a replacement part
I am trying to find a watch part for a Citizen Eco-Drive, movement no. 0850A.  The part no is 087-105 - "Minute wheel and pinion [II]"
The watch is over 20 years old and from what I'm seeing, most parts are unavailable.  But I thought I'd check to see if anyone could help, as my knowledge in this field is even smaller than the part I'm looking for.
16 minutes ago, Chopin said:
That part might be interchangeable with a few othe movements, just in case it helps. Not always like that but sometimes the same part is used in a couple of movements.
Do you have a photo of it ?
I'm hoping it's interchangeable like you said.
Unfortunately I don't have a photo, because I'm an idiot...I lost the part.  I went over the floor with my bare hands more than a few times on the weekend.  So mad at myself for this.  I was not prepared as I should've been when I opened the watch.
This is the closest I have to a pic.  I'm not even sure what color it is.
Thanks fellas.  I'm pretty sure it's plastic.  My wife suggested putting a sock over a vacuum hose and trying that.  I keep my room really clean...I thought...until I got down with a flashlight, LOL.  The only thing interesting I found so far is a staple.
It really is amazing how far things can travel, I was talking to a Watchmaker a few months back and he told me he lost a complete balance in his workshop and has still not found it!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Quote: No doubt I will find it when I retire and take all my work benches down.
I seem to be confused today? Would it be possible to attach the tech sheet you're getting the part number from? The reason for this I looked on a site to get a cross reference but the number doesn't agree with what you have? Then I am attaching a parts sheet and the number doesn't agree with what's on this sheet?
Citizen 0850.pdf
I called Citizen in California, and they do have part 087-105 in stock.
However 085A has no part of that number.
Now If you are talking about the Minute wheel and Pinion for a 0850A, it is part 072-1050
If you are talking about the Intermediate for second wheel it is part 087-1020 and Citizen has both in stock.
Here is a list of all parts https://boley.de/en/caliber/watchmovements/citizen/2047
John, you have the correct tech sheet, but look on the left side of the page (blue in my attachment)
RAT, it is 0850A.  As mentioned in previous post, the part I need is 087-105.  Elsewhere in the tech sheet, it is listed as "Minute wheel and pinion [II]" 1963220447_Mvmtno.jpg.4ce163b660d3e4e3c8e82118013db2c3.jpg
It never even occurred to me to just call Citizen.  That's excellent news if they have it!  That means I can stop crawling around on the floor with a flashlight, LOL.
Edited by Bluesrider
OK, NOW I'm confused.  I went back and looked at the chart, and as you said, not 087-105 for the 0850A movement.  That part goes in the 0870 movement.  The blowup graphic of the parts shows the 087-105 for my movement.
So here's what I'm thinking...if that doesn't go to my movement, maybe I never actually lost a wheel?  But it seems like there is a place on my movement for one more wheel.  A total of 11 in the graphic for the side of the watch I'm working on, but I only have 10 wheels.  My head hurts...
On 12/3/2019 at 11:57 PM, jdm said:
Do they sell to individuals?
No they do not sell to individuals, however I am an authorized Citizen USA dealer so with a simple phone call I have access to parts and technical information.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
    • @Murks the problem you have mate is most watch cases out there to buy are for Seiko NH3X, ETA 2824 and maybe Myota 8XXX movements, oh also the big ETA 6978/9 movements which the dials start around 28.5mm. You might find one on a Google search but I suspect your main chance will be buying cheap quartz ladies watches and hopefully find one of the right size and condition that is acceptable. 😞   Tom
    • The anchor pin should be perpendicular when the anchor is sat on a flat surface and if you post a close up picture of the backplate I will be able to tell you the correct torsion spring , running fast or slow is usually wrong Torsion spring. Here is a video from my YouTube channel showing how I set the beat
