seiko divers 200m problem
gary17
Hi
I was just trying to set the time on this seiko.
Instructions say turn crown anti clock wise and then pull. once to set date and twice to set time.
I tried this and the whole stem just came out.
I reset it and the same happened.
So after checking videos on youtube i had one more go and the result is in the pics below.
Is it just me or has anyone else experienced this problem?
Part of the stem is stuck in the crown as well i think
thanks
gary
I can't tell from your pics if the stem simply screws into the crown or was supposed to be attached to the crown without coming off (unless broken).
Many if nost most Seikos have the latter type where the two parts are not supposed to separate and if it does you need a replacement.
Did you pull too hard ? Was this the first time that you did this ?
I believe the dial is misaligned because the stem isn't holding it in place anymore. The case back also helps in this situation as it too holds movements in place, in general.
Does the stem screw into the crown tube ?
hi
No the stem does not screw into the crown.
I bought it at auction. downloaded the instruction pamphlet.
Followed it step by step and all that happened was the whole stem came out attached to the crown.
So i looked on youtube and it says try turning the crown a quarter of a turn anti-clockwise and try pulling the crown out. this i did and the pics show the outcome.
When the stem came out complete attached to the crown though rigid it was as if it was attached to the crown by a ball joint. There was lots of movement horizontally and vertically.
Just my luck i guess.
Thanks for reply
gary
Just for the record. If you only have a quarter turn hold on a screw down crown that means its threading is done with. Normal is like 2 1/2  - 3, one turn is just acceptable.
Hi
Just looked up cal and it's not recognised by cousins or ranfft also says made in China. Think this is my first error. Is this a cheap copy? I cannot get part I need. Doh
£15.00 wasted me thinks.
It works fine but cannot change time date or day lol
Gary
Hi Gary I also looked up the seiko 7N36C and found no trace even on the seiko site although that does not mean it never existed it may be that it is obsolete as so many quickly become in the quartz world.  I shall continue to search around and if I turn up anything I shall post it.  As Vinn says ok the price was not too bad so chalk it up to experience.  You may still be able to salvage the watch using a Hattori VX  or  Miyota movement of correct size .       all the best
I don't see anything that cant be put right. Hattori movements are not expensive, and they come with a new stem that would most likely screw into your crown.One would probably set you back less than the price of the watch. look on esslinger. They list a hattori 7N36 for $21.95  they image they show is marked 7N36C, looks like a spot on match for yours.
Edited by yankeedog
Sure it existed in the Seiko entry range ,attached the technical sheet. Dat/date setting could be possibly repaired and I think the replacement is 7N33.
7N35C, 7N36C.pdf
hey
yer i need the stem and crown as 1 piece all im seeing is the stem for sale.
Bought the stem but still not sure how this will help surely i need the complete unit
thanks everyone.
gary
Edited by gary17
You need to post the 7N36-XXXX reference on the case back to at least identify the stem/crown P/N.
But if the pendant tube threading is in poor shape (can't really tell from pic), it would be pointless anyway, don't throw good money after bad.
7 hours ago, watchweasol said:
Hi Gary I also looked up the seiko 7N36C and found no trace even on the seiko site although that does not mean it never existed it may be that it isas so many quickly become in the quartz world.  I shall continue to search around and if I turn up anything I shall post it.  As Vinn says ok the price was not too bad so chalk it up to experience.  You may still be able to salvage the watch using a Hattori VX  or  Miyota movement of correct size .       all the best
The Seiko part number for the movement is U7N3620 it is far from  obsolete in that Seiko lists 50+ in stock.
Also Miyota is a Citizen brand, it will not fit in a Seiko.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
    • Get someone local to tig it ,very easy fix and should only take a few minutes so probably wouldn’t cost much ,or failing that get it very clean and silver solder it. Dell
    • Hi, The winding pin is not split, well that's how it was when I obtained the watch. The movement is front-loaded and here's a picture of where the case screws are fitted. The face picture is before I dismantled it. Quick update.  I've always had a nylon ring sitting in the parts try that I wasn't sure where it went and left it to the last thing as I know it must be part of the case assembly. Anyway, looking at the picture in my last post you can see, just under the winding stem, a white-looking object, this is the nylon ring 🤭 So, I had to remove the dial again and replace the ring. Once this was all back together I placed the movement in the case and realized my initial problem maybe is not a problem as it looks like I can screw the movement back in the case and then place the hands as the dial is nearly flush with the outside of the case anyway so I'll be able to check for alignment. if all is good then just fit the crystal and bezel 🤔 I can't think of any issues with this approach but please comment if you think I've not thought of something. Another lesson learned as well. Take more pictures not just of the movement parts and location 😅
