balance spring loose frpm spring stud
gary17
Hi
I was trying to fit this balance when i noticed it was lose.
I have not had much success with balances before so wondered if someone could tell me the best way to go about reconnecting it to the spring stud without destroying it.
It is still connected to the spring boot.
See pics.
Any help (advice) would be a great help.
Do i remove the spring totally ?
Try to reconnect it from the way it is now?
How can i loosen the stud screw without it moving away from me?
Can i put it in a vice?
What parts can i hold in a vice?
Thanks
gary
Sorry pics aint great but best i can do with phone camera
The pictures are not too clear, but is the spring lying to the outside of the stud presently?  I can see a brass pin in the stud, but is there a screw protruding from the actual stud as well?
Stick the balance down on a piece of Rodico or bluetack.  Assuming a standard stud and pin set up, I would carefully try to remove the brass pin from the stud.  Then I might well remove the stud from the cock, and try to slip the HS thru the stud hole and then remount the stud in the cock.  Then try to carefully re-insert the brass pin to secure the HS.  Realize even if successful, you will have likely some timing issues if you don't get the HS/Stud position just right as the spring was initially vibrated to determine the position in the stud.  That's my take and it will be a bit of a PITA to do this so take your time and get it as close to right as possible.
Good Luck.
RMD
Hey
Yer removed brass pin and the stud. Only thing is now i do not have the magnification to see them close enough to attempt to try to slip the HS through the stud hole. Hope santa brings me a scope that i can use to see them.
Thanks for your help. Im sure it would have worked if i could just see the damn parts.
cheers
gary
Hi Gary   have a shufty on the bay there are some electronic scopes on there probably chinese reasonably priced and do a reasonable job. Ihave one and had no problems with it.  A double lens loupe of suitable magnification should enable you to fit the spring ok. The method I have used is re fit the stud to the cock lay the balance on the cock, remove the pin and manipulate the spring into the hole then fit the pin, tight enough to hold it in position so that when re fitted to the movement any timing issues can be addressed by altering the spring in situ. As mentioned by Rduckworth its a PIA and takes a lot of patience to achieve
    • An incabloc spring? About 10p at the current price 🤣
    • Have you ever seen grease spread?  I use Molykote DX on the keyless, cannon pinion, etc and cannot imagine it spreading. Similarly, HP1300 should not be a problem, as long as you don't splash too much about.  9010 does like to travel though. I've recently re-serviced a couple of my watches I first serviced about 5 years ago. I was a bit too liberal with the oil and grease back then, but it hasn't spread everywhere. I only epilame on balance cap stones, escape wheel and pallet stones (and auto wheels if they need it).   If you use it all over, the oil might bead-up and travel even further - think of using RainX on your car windows.
    • Polish it where the old part cracked as well. Get rid of the stress-raisers.
    • Sounds great! And yes, I would use grease for the keyless as well although treating the parts with epilame would make the grease less likely to spread in the long run. Not critical but won’t hurt. My current strategy is to epilame treat all parts getting in contact with oil or grease.
    • Hello everyone, for what it's worth, here is my approach: 1. Escape wheel submerged in Epilame, then dried quickly with a hairdryer. Then the final tip of the pivots are cleaned by poking into pithwood. The logic being that the Epilame is removed at the intended contact point (to avoid any residue that may mix with the oil), but remains in the areas where oil is not supposed to spread to (further down the pivot towards the wheel). The escape wheel teeth also benefit from having Epilame to keep the 9415 in place.  2. I use a syringe to treat only the pallet stones. I suspend the pallet fork with some Rodico so that the stones hang downwards. I notably use a rather thick needle where a drop WON'T form, but rather where the Epilame liquid stays in the needle tip, which I then dip into the pallet stones. It requires some practice to get the right amount of Epilame into the needle tip, but it works for me now. This way, no drop will "jump" onto the pallet fork and potentially go all the way to the pivots.  3. I let the movement run for a few minutes without lubricating the pallet stones... to scrape off the Epilame in the intended contact "channel". Then I remove the balance again and lubricate the exit pallet stone with 3-4 successive drops. See the "channel" that forms on the pallet stone in the picture -- not so easy to see, but it's visible.       I am conflicted about the use of Epliame in balance jewel settings. My impression is that the two jewels sufficiently suspend the oil (even 9010). Apparently Rolex recommends NOT to use Epliame there (heard from a former Rolex service center watchmaker), as it could cause additional wear. Apart from that, I follow specific instructions where I can find them. E.g. the infamous Rolex reverser wheels or sometimes (parts of) the seconds wheel. Exception: I'm currently servicing an Eta 2824 and will probably ignore the service sheet that recommends treating the whole keyless works with Epilame and then using HP1300... I'll skip the Epilame and use 9504 grease.
