Springbar removal & refitting tool for drilled lugs
m1ks
Happened to be given a springbar tool for drilled lugs to try out and review, have been chatting with the maker and having suggested the possible addition of fork tools for standard bracelet lugs also, (like the expensive Bergeon tool), he's going to look into incorporating that.
Link to review here for those interested.
https://www.youtube.com/watch?v=vSutgRceWIk&t=35s
6 hours ago, oldhippy said:
Never needed such a gimmicky tool. I used an old screwdriver with a blunt end, a case knife and an old screwdriver with a blade end.
Me either until I tried it. Like I say in the video and as I've said many times when I was a working mechanic.
Can you get by without? Yes.
Does it make the job easier? Yes.
The amount of modified 'special' tools for one off mechanic jobs in my tool box have saved countless hours of swearing and frustration.
The watch I demonstrate on has the tightest fitting solid end links I've ever encountered. Very well machined and zero wiggle which makes using a spring bar tool to remove a real fiddle.
4 hours ago, JBerry said:
Nice idea, seems a bit fiddly to keep the pins parallel to each other though
If the springbar ends were flush with the case sides it would be but once located into the holes it's locked in place.
He's looking into adding fork tip tools in addition to allow opening non drilled lug spring bars in addition which I think will make this a very handy tool to have.
That is a good idea, but affordable alternatives are already available. https://www.aliexpress.com/item/33037218060.html
    • Just a note for those who come searching for information on this topic in the future.  I did eventually find the Mark's video on how to replace these springs, as someone observed, he does in fact make the replacement look easy.  (It actually is relatively easy once you have the knack of it.) If you're enrolled in one of Mark's online courses, the demonstration of how to replace this spring is in the Bonus Videos section of his course site, and is called "C2B1 – Sea-Gull Style Shock Springs".
    • If the metal was twice as thick, it wouldn't snap so easily.  The thickness is governed by the space available so you can't use thicker metal.  If you glued two pieces together, the likelihood of snapping would be reduced.  That's my theory anyway, could be wrong.
    • there are various approaches to learning watch repair. A lot of people want to jump right in and every single watches something to be repaired restored. But other times like this it's disposable it's here for you to learn and when you're through learning you throw it away. yes you definitely should try this you have a learning movement you need to learn and the best way to learn is by doing something.
    • Sorry, the friction will be so great that the wheel will barely turn, if the movement will start at all, the amplitude will be verry lo.
    • If I can’t re-pivot the wheel, the logical thing to do is to descend the pivot hole.  Plan is to either stick a suitably sized hole jewel (from a barrel bridge or something) or fashion a blob of epoxy on the underside of the escape wheel cock so the wheel sits on its one pivot on the base plate and the staff with the broken off pivot (which I’ll polish as best as I can) becomes the upper pivot. As long as it doesn’t foul the 4th wheel it should work? I know it’s a bodge job, and if this were a rare movement, or belonged to someone else I would not do this. I’m just interested to see if I can get the thing to run.
