Springbar removal & refitting tool for drilled lugs
m1ks
Happened to be given a springbar tool for drilled lugs to try out and review, have been chatting with the maker and having suggested the possible addition of fork tools for standard bracelet lugs also, (like the expensive Bergeon tool), he's going to look into incorporating that.
Link to review here for those interested.
https://www.youtube.com/watch?v=vSutgRceWIk&t=35s
6 hours ago, oldhippy said:
Never needed such a gimmicky tool. I used an old screwdriver with a blunt end, a case knife and an old screwdriver with a blade end.
Me either until I tried it. Like I say in the video and as I've said many times when I was a working mechanic.
Can you get by without? Yes.
Does it make the job easier? Yes.
The amount of modified 'special' tools for one off mechanic jobs in my tool box have saved countless hours of swearing and frustration.
The watch I demonstrate on has the tightest fitting solid end links I've ever encountered. Very well machined and zero wiggle which makes using a spring bar tool to remove a real fiddle.
4 hours ago, JBerry said:
Nice idea, seems a bit fiddly to keep the pins parallel to each other though
If the springbar ends were flush with the case sides it would be but once located into the holes it's locked in place.
He's looking into adding fork tip tools in addition to allow opening non drilled lug spring bars in addition which I think will make this a very handy tool to have.
That is a good idea, but affordable alternatives are already available. https://www.aliexpress.com/item/33037218060.html
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
