Spaceview yellow dot crystal
Stevelp
Hi all!  So I have always been a fan of the Spaceview Accutrons so when one came up for sale in my small town I thought I would take advantage of the opportunity.  Overall I would say the watch is in decent condition, but scratched crystals tend to get to me a little bit.  Just curious if someone might have the part number for the original yellow dot crystal as I don't want to put a reproduction on.  Also, I see a lot of the yellow dot crystals for sale that say they are luminous and mine does not seem to be.  Did some have the luminous crystal and some not?
I have had success as well with things like polywatch.  I figured because the inner workings on the accutron are so interesting and tend to be a focal point all of the somewhat deeper scratches that are left behind to me would still feel kinda obvious.
That is certainly a plastic crystal and can be polished perfectly as a matter of general maintenance, if it's original it would be a travesty to change it out. Gorgeous watch and yes some models were luminous and some were yellow painted. Don't change it, they're different models and all original configurations are relatively rare. I'd rather have that one with a nicely polished orig crystal than with an nos crystal that's two weeks away from looking like the one you just polished anyway. :)
vinn3 you are absolutely  right it is acrylic.   I know some people say that scratches and bumps and such add to the watches character and patina and I don't debate that but if I can I like to start fresh.  But being a bit more or a rarity I think I will give polywatch a go and see what kind of result I can get.  Upon inspection it seems that this crystal has the painted dots and not the luminous dots.  Ill keep you posted on the results.  Thanks everyone for the input!
    • So here is the new base, I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded. The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool. Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder v2.pdf Modular Movement Holder v2.pdf
    • Hi Frank, you have dived headlong into the deep end. Hairspring work has to be the scariest thing a newbie has to tackle. Your hairspring appears to be bent and just putting it back into the regulator would not allow the balance to work properly. It might start oscillating but the performance would not be good. The proper thing to do is to unstud the hairspring, remove the hairspring from the balance, reinstall the hairspring on the stud carrier, reshape the endcurve and centre the collet to the balance jewel hole. This challenge would either make you or break you. Hope that you will be able to fix your watch. Welcome to the world of watchmaking.
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
