Glass removing pump
Alaskamick
I know that the Glass Removing Pump is a good way to get domed crystals off front access watches to do a quick repair on the fingers but has anyone had experience of them and will they work with Seiko flat glasses which are pressed in.
They are not cheap but if ok could save loads of time.
U can use a large syringe instead of a pump. Put a piece of plastic bag like a ziplock bag over the crowntube and then the syringe over that . But use only on acrylic glasses. If you use it on mineral they could break. i have never seen a Seiko though  with such crystal. If they are front loaded they have a crystal retaining ring to hold the crystal in place.
29 minutes ago, jdm said:
Which Seiko glasses exacly? If the watch has a removable case back, use a press not a pump.
I just thought it would be easier to use a Pump rather than fetching off the Back, Stem + Case Clamps then pressing out the crystal and having to do it all in reverse to put it back together.
No particular Seiko but I have done a couple recently with flat glasses that press in and out.
On even a 60m WR watch I don't think the glass would pop out as the gasket keeps it in place tightly.
To use a pump you have to remove caseback and stem, then refit the caseback but on Seiko 5 and divers (no casing tabs) the mov't would come out that point. Then to refit the glass a press is needed anyway.
That's why you should use a glass not a pump when the caseback can be removed.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
