Eco-Drive capacitor replacement
I have the watch shown in the pics, which I purchased in 1998.  The capacitor has been slowing down for years and finally won't hold charge.  (Pretty amazed it lasted this long).  All the videos I see online about replacing an Eco-Drive capacitor look similar to a typical battery replacement, but this one's buried.  After getting the back cover off, I removed 3 screws which I hoped would allow the matal cover to be removed, but it looks like there's a lot more to it.
This one may be above my pay grade, but I wanted to ask, maybe there's something simple that I'm missing.
Thanks for any help you can provide!
You are going to have to take that back plate off but you've done the right thing stopping when you were unsure.
We need to try and find the movement reference. This is probably around the area I have marked in your picture - I just just about mae out Citizen and Japan but there's too much shine on it to see a number reference. When replying also include a copy of the case back as that can sometimes have useful information stamped on it.
If you  remove the module from the case (stem release is clearly marked, a good Japanese habit) you will be able work more comfortably using a mov't holder ($2) and clean thoroughly the stem tube and crown, and lightly lubricate the stem body (Moebious HP-1300) and gasket (silicone grease), that's always good to do.
Well, thanks all for the help.  Unfortunately this endeavor was doomed from the get go, way out of my league.  A friend of mine, who actually is a professional watch repair guy, sent me a tech sheet with the numbered steps to disassemble & reassemble the watch.  You have to remove the face, hands, etc, a total of about 20 steps on both sides of the movement, before getting the capacitor out correctly.  i was able to get it out, but not able t get the new one in without removing additional parts, and then I went too far, which resulted in tiny wheels lying all over the place.  I spent a couple hours on it, but hit a wall.
I have no idea if this is something Citizen would put back together without charging me an arm and a leg or what.  Not a crisis, it's just a watch.  I'm just disappointed I wasn't able to do this.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from .
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
    • @JohnR725 now that you've mentioned it. This is actually the second aftermarket spring (same place and brand) I ordered as the first one broke. The eye on which the arbor pulls on, broke off on the first spring after the first wind, and also it was a bit to large for the arbor. Looked like on one the second picture in the 2nd group. The second one was exactly the same, I had to bend it a bit, to give it a more prominent curve to the end of the spring so that the arbor catches the eye.  Also I believe both were 5-10mm shorter. Not that I writing that, I feel a bit dumb, as the spring might actually been the problem all along, although its advertised as a substitute to the original...
    • The CS70 is the only one they show as annealed.  A further search on ebay, I found CS75 and CS100 annealed carbon steel strips  e.g. https://www.ebay.co.uk/itm/314072784422
