Hello from the bench
Otto
I have decided to join your Watch repair talk group after searching for a 2 way street group and people that have a passion for Time pieces not just to drain your knowledge,time and parts  , I am a second generation watch and clock maker , Yes and clocks :) , Thats the way my dad taught me starting in 1975 and I continue the same way today , He was strictly watch repair until 1968 and when the quartz watch took hold he thought he would tool up for clocks in fear of a decline in watch repair , shortly after he started his clock repair he took on repairing Tube radios , Knife making , Antique Music box restoration and much much more ( Im sure Mom had something to do with it as well ) ha. My mother had the Victorian  Antique Store and was the go to person on estate jewelry , Glass, Anything brass , Tiger Oak , Dolls Etc Etc . I say all this to let people know the environment I grew up in. Amazing and tremendous adventures, knowledge etc. , absolutely no regrets !!!! Except for when we slept in the van at certain shows haha. To be able to do what is your passion and make money at it too, AWESOME. And a job you can never master !!!! Always something to learn and explore. I have been very reluctant to join horology sites for the simple reason TIME and Respect . I have tried a couple blogs in the past and it turned out that people were not respectful of my time . I can not fix a watch , Clock over the internet or phone and Im not looking to drum up more work . I have more than I can handle .  Knowledge , parts and correct Tools is how its done .As long as this group is a 2 way street then Ill stay :) .
    • Hello everybody, sorry for the late reply. Thank you all so much for your help and your tips. I got lucky and found a replacement wheel bridge for cheap which actually ended up being in decent condition. I decided not to do anything about the mainspring barrel pivot since I didn't have the right tools and the barrel didn't have much endshake anyhow. I am happy to report that the watch now runs great, I have regulated it to about +-10/s day which is fine by my standards. The timegrapher result looks decent as well, although beat error is around 0.6ms which could be better I suppose. Amplitude reaches over 230 quite consistently which I'm happy with also. My lighter fluid has also been replaced by balance spring cleaning solution and now the springs don't stick to themselves anymore - who would have thought. I'm super happy with this watch, it might not be worth a whole lot but it's awesome that I could restore it and it makes me wear it with pride. To me it's a genuinely good lucking watch, it'll be my daily driver for a while. Thanks again to everybody for their input! I couldn't have done the repair without your help.   Here are some images for those interested, the bracelet isn't original but I don't really mind:
    • Balance-hairspring system is oscillator with big Q-factor. When all in the movement is OK, the rate (frequency) is verry close to the own resonant frequency of the balance-hairspring. But in some cases, the movement (with foult) will force the resonator to work on pritty different frequency, sometimes faster, and sometimes slower. When this happens, the amplitude is always weak. So, the first thing to ask is what is the amplitude. If it is more than 180 and the hairspring doesn't touch itself and anything else, then for sure it is 'short'. If the amplitude is weak, then the first thing to do is to understand why and rectify the problem. At this time no point to check timekeeping. But, if one doubts that the hairspring is not correct, then He needs to calcullate the rate of the movement, then to 'vibrate' the balance-hairspring out of the movement and to measure the free oscillations frequency (period) with timer in order to ensure that they comply with the rate. If we have pictures, then it will be easier to tell something about that wheel.
    • So much work has gone into this! Thanks again @Jon. I will go back and check my adjustments from last weekend. A few questions for you, if you don't mind. In the reset position, I can understand the problem if the gap between the hammer and the minute counter heart is too big (slide 77) but what is bad about both hammers being in contact with the cams (slide 76)? I read somewhere that Landeron recommended grease on the runner cam, but the minute counter heart should be dry. Is that so, and why? How many tads in a ligne?
    • Could you glue two pieces together for rigidity and separate after forming?
