Enicar dating
Hi
Weasol
I would put photos up but i bought the watch today. I have just tried to remove the back with all the usual suspects but it wont budge.
It was sold to me as just been serviced. So back should have screwed of easily.
IF i continue any more with it i may damage it .
So its going back to the seller for refund.
thanks anyway
gary
Not sure what the "usual suspects" are but not having the correct tools does not seem a good reason to return an item.
8 hours ago, gary17 said:
Hehe
You turn it a quarter and then lift its a bayonet fitting. Pics
 Up tomorrow
Gary
Enicar had two type of caseback.. the bayonet type and a screw type.
The giveaway is a little triangle around the edge of the caseback. I believe this was supposed to line up with a reference on the case.. or maybe the crown.
Good job figuring it out, took me a while too!
Anilv
14 hours ago, gary17 said:
a jaxa wrench
And the 3 claw wrench.
After that I usually glue a wrench to it.
Any other methods I'm willing to try.
Yes, a bench opener. With the proper dies it opens any tight watch, as none of the tools you mentioned places vertical pressure on the caseback, nor holds the case securely. A two handles Jaxa opener also is a step forward.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
