Enicar dating
Hi
Weasol
I would put photos up but i bought the watch today. I have just tried to remove the back with all the usual suspects but it wont budge.
It was sold to me as just been serviced. So back should have screwed of easily.
IF i continue any more with it i may damage it .
So its going back to the seller for refund.
thanks anyway
gary
Not sure what the "usual suspects" are but not having the correct tools does not seem a good reason to return an item.
8 hours ago, gary17 said:
Hehe
You turn it a quarter and then lift its a bayonet fitting. Pics
 Up tomorrow
Gary
Enicar had two type of caseback.. the bayonet type and a screw type.
The giveaway is a little triangle around the edge of the caseback. I believe this was supposed to line up with a reference on the case.. or maybe the crown.
Good job figuring it out, took me a while too!
Anilv
14 hours ago, gary17 said:
a jaxa wrench
And the 3 claw wrench.
After that I usually glue a wrench to it.
Any other methods I'm willing to try.
Yes, a bench opener. With the proper dies it opens any tight watch, as none of the tools you mentioned places vertical pressure on the caseback, nor holds the case securely. A two handles Jaxa opener also is a step forward.
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Here is the fake .pdf for just the FreeCAD base file and 3mf files Modular Movement Holder.pdf Here is the fake pdf for complete set of the new base and ring FreeCAD/3mf files: Modular Movement Holder base and ring v 2.1.pdf However, I'm wondering how often you could use this feature, adding the dial usually increases the OD of the movement, so you would need a new (larger) adapter ring tuned to the OD of the dial and I wouldn't like to grip the dial in any kind of movement holder if It could be avoided for fear of damaging it. Maybe I'm misunderstanding you?
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
