Enicar dating
Hi
Weasol
I would put photos up but i bought the watch today. I have just tried to remove the back with all the usual suspects but it wont budge.
It was sold to me as just been serviced. So back should have screwed of easily.
IF i continue any more with it i may damage it .
So its going back to the seller for refund.
thanks anyway
gary
Not sure what the "usual suspects" are but not having the correct tools does not seem a good reason to return an item.
8 hours ago, gary17 said:
Hehe
You turn it a quarter and then lift its a bayonet fitting. Pics
 Up tomorrow
Gary
Enicar had two type of caseback.. the bayonet type and a screw type.
The giveaway is a little triangle around the edge of the caseback. I believe this was supposed to line up with a reference on the case.. or maybe the crown.
Good job figuring it out, took me a while too!
Anilv
14 hours ago, gary17 said:
a jaxa wrench
And the 3 claw wrench.
After that I usually glue a wrench to it.
Any other methods I'm willing to try.
Yes, a bench opener. With the proper dies it opens any tight watch, as none of the tools you mentioned places vertical pressure on the caseback, nor holds the case securely. A two handles Jaxa opener also is a step forward.
    • Hi. Yes I get it , the slot in the end I’d to allow you to screw the button on whilst holding the pusher shaft. To remove the pusher tube you will need a tool such as the one shown by Richard. I think Ali Express the Chinese Amazon has replicas of the Horotec system for a lot less money, how effective they are not having had to use one. But as you said the way to go is complete removal and replacement, bodging it up will  lead to a repeat failure
    • It does look like it seems to be working again I'm getting emails.
    • One of the things that I've been bothered with lately is timekeeping? For instance a 90-year-old pocket watch what so to timekeeping was it supposed to keep? They publish railroad timekeeping but I don't know how well normal non-railroad watches were supposed to keep time. The reason why the question comes up for me is I spend a lot of time at work adjusting watches to keep really really good time  because I have to please my boss where as when the watch was made I have to wonder what kind timekeeping would've been acceptable. After all they typically didn't have timing machines 100 years ago and they were timing and six positions certainly not for the non-railroad grade watch. On the other hand I do get paid by the hour so maybe I shouldn't be concerned of how much time I Spend trying to make everything keep chronometer timekeeping almost. Citing a Delta of 40 seconds for a 90-year-old watch is quite outstanding.
    • That's an interesting question which I don't think I've seen explained anywhere. But I think the problem will go away just about instantaneously. In other words the  coating is really thin and it should go away almost immediately. So the problem should resolve itself extremely fast.
    • I experienced that different types of shellac and their ages are affected differently by IPA. Sometimes the shellac dissolves in a few seconds and sometimes several minutes are required. Nowadays I never let shellac come into contact with IPA. It's a hotly debated topic here on WRT if you search. Like John, I don't think you need to worry about the weight of the shellac, but instead that it might start rubbing against something. When I learned how to adjust pallet stones, I tried documenting my experiences in this thread. Hopefully, it can help you. I personally don't believe in the idea of abrading the epilame before oiling so I don't think you need to think or worry about it. The only time I've heard anyone mention this is Alex on the YouTube channel Watch Repair Tutorials but actually no one else. I'm not saying it's "wrong" just that I don't think it's necessary or adds anything.
