Enicar dating
Hi
Weasol
I would put photos up but i bought the watch today. I have just tried to remove the back with all the usual suspects but it wont budge.
It was sold to me as just been serviced. So back should have screwed of easily.
IF i continue any more with it i may damage it .
So its going back to the seller for refund.
thanks anyway
gary
Not sure what the "usual suspects" are but not having the correct tools does not seem a good reason to return an item.
8 hours ago, gary17 said:
Hehe
You turn it a quarter and then lift its a bayonet fitting. Pics
 Up tomorrow
Gary
Enicar had two type of caseback.. the bayonet type and a screw type.
The giveaway is a little triangle around the edge of the caseback. I believe this was supposed to line up with a reference on the case.. or maybe the crown.
Good job figuring it out, took me a while too!
Anilv
14 hours ago, gary17 said:
a jaxa wrench
And the 3 claw wrench.
After that I usually glue a wrench to it.
Any other methods I'm willing to try.
Yes, a bench opener. With the proper dies it opens any tight watch, as none of the tools you mentioned places vertical pressure on the caseback, nor holds the case securely. A two handles Jaxa opener also is a step forward.
    • Hi! I am in the process of restoring a rado captain cook mkII. I want to remove the rotor, but I am not sure how to and need some help. As you can hopefully see on the photo there are 2 screws. The left one has two positions, the right one looks like a regular screw. I have tried turning the right one, but it does not give even after using more force than I would expect. Anyone know the function of the left screw with the two positions and how to remove the rotor? Thanks!!
