Aeromatic 1912
Rosco1
Hi Everyone, I have been given an Aeromatic 1912 watch for repair and am trying to identify the movement in case I need spare parts. (see pics below)
Note the inner ring of numbers are mirror reversed! It is a Chinese movement marked 19 ZUAN ZLC.
Can anyone tell me what the double ended hand at the 8 O'clock position is called? It seems to just oscillate with the balance wheel.
I have had no luck locating this movement on the internet.
Isn’t this a version of the famous Chinese ”standard movement” that was introduced in the 70’s and produced in millions?
They were built by a multitude of factories, Zuan is probably one of many.
I have a friend who several years back bought a bunch of NOS watches directly from China where they had beem lying impossible to sell since ”quartz revolution”. Now they’re becoming collectibles, I hear.
May be hard to find specific spare parts but donor movements/watches similar enough might be possible to find on the web.
I suspect the mov't is designed to have seconds either central or at 9 with just different assembly. But in this case, to add visual attractiveness, the oscillating bar was added.
Zuan means jewel in Chinese. ZLC is for Liaocheng Watch Factory.
http://chinesewatchwiki.net/Common_markings_on_Chinese_watches
Edited by jdm
https://en.wikipedia.org/wiki/Chinese_standard_movement
Donor "Tongji" movements are relatively easy to find, and since they are "standard", most parts are interchangeable, with the possible exception of the modified parts used to add that oscillating hand.
The parts are often, even interchangeable between the automatic and manual wind versions. Furthermore, this movement is still in production in various forms, and at various facilities in China even to this day.
Thanks everyone for the replies and valuable information. It was the oscillating hand that puzzled me as I could not find any trace of it online but it sounds like it may be just an addition to the standard movement. The steep  learning curve continues.:)
8 hours ago, yankeedog said:
Interesting..a gimmick to be sure.but it could  give you an idea of amplitude.dim electric  light might act as a strobe.60 hz is a multiple  of 18000 bph.
Well,  China mains are 50Hz. Both 50Hz and 60Hz are submultiple of 18,000 bhp (5Hz), but I doubt that can be used to get an idea of rate, and certainly not amplitude, because that pivot is not tied to the balance.
Edited by jdm
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
    • Once a movement has the dial and hands put back and it is recased, would you expect the assembled watch to have the same amplitude as when the movement is in a movement holder and is without hands and dial? Thanks
    • C07641+ not sure what the "+" is for after the last digit.
