New Member, My Longines From 1942
nebulight
Hello everyone. I found this place after binge watching most of the videos from YouTube. I picked this up a few months ago. It's a 37mm greenlander case set but with a standard gilt dial without lume and sword hands instead of cathedral. The case back also does not have an www engraving. I prefer this version compared to the military issue greenlander.
oRVJk7B.jpg?1
Sent from my mobile phone using Tapatalk
    • Well I’ve never seen the make before and cannot find any info, I haven’t got it just yet it’s been left to me among a 1970’s sea master and a mid size yeoman. But if anyone has any information on this one please feel free to enlighten me, many thanks
