Hairspring not right
gary17
Hi
I needed a escape wheel for a omega 565 the one i had the shaft had broke at the top.
I managed to get a omega 562 donor i removed the aut0 wind and the train bridge and fitted it.
But now when i look at the spring on the balance it looks wrong and different from when i started. I have put some pics up (best i can do).
I have removed it and replaced it a few times and its the same.
When i let the spring dangle from the bridge it looks lob sided.
I have checked with the donor movement and the damn thing looks the same on that one.
Any ideas appreciated.
Sorry with my terminology, i am trying just not confident enough to use it.
And yes they both looked fine when i started and all i have done is remove the escape wheel from the donor and added the escape wheel to the other watch
cheers
gary
You need to take it off the balance and lay it down on a bare balance cock and see how it aligns with the collet and upper jewel; as well, how does it ride along the regulator. If all aligns, non issues, if not, you need to manipulate the hairspring. Check out Marks videos on how this is done or YouTube to at least see the technique. This is not beginner stuff btw.
JD
This is the hairspring which now looks like a bird's nest, right? Here it looks like the outer coil is snagged on the inside of the boot and has been forced above the inner coils.
Can you get pictures of the one on the donor movement? One similar to this, and one in the plane of the spring. Then one of the balance and spring assembly separated from the cock.
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
