Low escape wheel
Ammar
Hello,
I am working on a Citizen 8200a movement that was running slow, I took it apart cleaned it and started putting it back together but the escape wheel decided to troll me and sit lower than the pallet fork and not even reach the bridge and the second wheel.
I checked the pivot,the jewel (which is flush with the face of the plate i thought I somehow have pushed it down but apparently I havent and it's not broken) and the bridge ian't bent and what is annying me is the watch was running.
By the way the main bridge or what ever it's called on this movement is a pain in the neck to put back in place I don't like it.
56 minutes ago, oldhippy said:
Did you remove the end stones if any? If so have you put them back in the right order. I would like to see some photos as I can't remember much about this cal movement, both side of the plates please.
There is no end stones on this movement (I have done this mistake before ^_^)
2 minutes ago, watchweasol said:
Hi Ammar  just a thought  if there are no jewel settings to have moved, Have you fitted the wheel upside down therefore putting the wheel on the wrong plane ?????. I have attached the tech sheet to help you
Hi I fitting the wheel the right way I am sure of that, I have a couple of spare wheels from another movement I'll see if the fit and have a try although the pivits on this wheel looks absolutely fine but I am out of ideas
49 minutes ago, watchweasol said:
Hi Ammar another thought and I have done this my self when rebuilding movements, Is the fork/pallet the right way up if not it would be the same , out of line.
I think you are right on this, or the pivot has been replaced at sometime and slipped in a tad further than was first fitted..
14 hours ago, Ammar said:
Hello,
Sure you got the other wheels in the right way up or in there jewels . Could be tricky to get all pivots in place. And the click is in place on the ratchet wheel.
3 hours ago, Ammar said:
uh um the second wheel pivot snapped on me yea... I hate this movement
Not the easiest to align all pivots on this . Has snapped pivots to. BTW which wheel do you mean? The wheel for the second hand don't have a pivot . Sweep second pinion it's called.  Think it's a spring that holds it down or up .
I meant the wheel that meshes with the escape wheel I was so frustrated when I made that comment didn't think of the terminology (not that I know what it's called any way).
I have another spare movement coming my way hopefully I can get it right this time  ^_^
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
