guide to watch polishing
east3rn
Hello.
I recently got interested in watch polishing.
Since I usually work with vintage watches, I would like to learn how to polish a acryl crystal. I tried polishing acryls by hand with sand paper and Polywatch but
it owed me a quite amount of time and effort.
Also I want to move on to case polishing as well.
I looked up the internet to find a full guide on watch polishing but I was not lucky enough to find the one that seems like a "complete guide" on polshing.
Would there be a source from which a hobbyist can train oneself to become a pro in watch polishing?
Any advice would be grateful! Thank you and I always appreciate your kindness.
I don't know of a book but you can get a starting point by the video below, and the many, many topics on this forum that you can find using the search box top right.
Edited by jdm
I created a thread on the question, titled.
' How are stainless steel cases polished '  about two years ago.
Among respsonses, jolly good fellow Jguitron showed samples of his work, told about the compounds, other details and offered to work with me and get me on rolling.
Jdm said it, search for many related topics on the forum.
Best
Feel free to link it anytime. Also, moderators can make it pinned and/or starred, so it stays on top of the topics list.
17 minutes ago, Nucejoe said:
I don,t know , how to link or quote a portion of texts. Old guy old ipad.
With browser copy and paste. Go to desired topic or website, click address bar, copy. Then paste into any other topic or whatever else.
You can also highlight text in a previous post, and a highlighted option box *should* pop up to "Quote selection".
Like a lot of things that should just work, this can sometimes be a bit hit and miss, so try selecting the text again if it doesn't work the first time.
See the example below.
Just to avoid confusion, the above is an image, so it generally wont work if you try to select part of an image, but will work if you select text. Try highlighting this BOLD text to see what I mean.
Quote
You can also hit the image.png.e57a35ea45151b5958d7afe4c6607ac9.pngin the editing options and put whatever you like in a "Quote" box like this.
Edited by AndyHull
    • that band is old as stated, there is a kit that pops up from time to time on selling sites for the repair of these type bands, some of this type are adjustable on a few links, one adjustable type allows you to align the round opening in the expansion slit [like yours] with the rivet to separate, but if yours won't come out then the rivet head is too big and will have to be done with some rivet removal and replacement, I suppose if you could make/optain the correct rivets that one could alter the said band, the tops/caps do lift off after raising the tabs....
    • This is a watch from a friend who sent it to a neighborhood watchmaker for a battery change. It came back with the watch stem in a ziplock bag and the dial skewed 20°. The watchmaker told him that the stem was faulty and the watch cannot be repaired. I opened up the watch and found that one dial foot was broken off and still stuck in the movement, while the other was bent until it was flat against the dial. The stem could be inserted but it couldn't be pulled out to quickset and time adjusting positions. I did a full disassemble, cleaned and oiled the movement. But when it put in the battery, the second hand runs super fast. Like it gains 30 mins every hour. Any advice on fixing this problem? TIA.
    • I determined that the balance staff is rotating, not the roller table, so my second attempt at riveting was unsuccessful. I have ordered a new balance staff and will take measurements when it arrives. The balance staff i originally ordered (and now reordered) was specified as: Replacement balance staff: (A. Schild Caliber 984 1002 1021 1124 Original Balance Staff Part 723) so it should be correct. Measurements: (see pic below for terminology) xxxyy is a place holder until the new balance staff arrives. Lower pivot: Old - .08 mm New - xxxyy Lower pivot to balance seat: Old - 1.53 mm New - xxxyy Roller shoulder: Old - .42 mm New - xxxyy Hub: Old - xxxyy New - xxxyy Balance shoulder: Old - .86 mm New - xxxyy Collet shoulder: Old - .56 mm New - xxxyy Upper pivot: Old - broken New - xxxyy
    • Hello and welcome from Leeds.  We're here to help.
    • I was just about to adk that, probably they have unnecessary waiting lists to make their watches appear more exclusive than they actually are.
