Timex Dial Tabs
bluerich
I've recently gotten interested in Timex electric watches after finding one at an estate sale. The watch is a 1979 model 262 and it needed a lot of help. The back plate was missing and the movement had been heavily oiled. I've picked up quite a bit of valuable information from all of the experienced people on the forum, in particular Jersey Mo. One thing I haven't seen is any posting on how to deal with the fragile tabs that hold the dial onto the movement. It seems a weakness in such otherwise robust watches. I thought I was finished with the model 262 I've been working on but I had to remove the dial again due to problems with the day/date changing. Sure enough, one of the tabs snapped off when I was putting the dial back on. Anyone have any advice on how to fix broken tabs or re-attach a Timex dial with a few (or all) tabs broken off? I thought of UV liquid plastic but I don't think it would hold for long. Seems like crazy glue or a bit of solder might work but then things can get sloppy pretty quickly. My current project is back together with 3 tabs and I'm sure will hold for now.
thanks
One of the things that I've done in the past with Timex dials is to use a two screwdriver method of bending the tabs. I'll take one screwdriver, and use it to support the back of the tab, and then use the second on as a lever to actually bend the tab. The goal is to have the tab bend somewhere other than where it joins the dial. Don't want repeated bending in the same place, failure will be inevitable.  I can't say for sure that my method is 100%, but it seems to help me avoid broken tabs.
I've tried dial dots to fix broken tabs, so far no success.  Someday I may try soldering a new tab, but I have yet to be motivated to put that much work in to a Timex dial. A new tab could probably be soldered much like a new dial foot can.
Thanks dadistic for your tab bending tech. I have tried a variation of it with the goal of not bending at the point of contacting dial and it does work well. I did put too much pressure at that point when I broke the one tab and I could just feel it was going to happen. And thanks for the dial dot info too as this was another method I wondered about, And, AndyHull, I don't know what the dial is made of but I think it is brass. I'll take a closer look at it later.
Thanks
I haven't messed with a Timex dial but I have with others similar.  I used a very thin piece of  brass sheet and cut it to a T shape.  I bent it at 90 deg then used JB Weld to fix it to the underside of the dial with the top of the T on the dial and the leg of the T used for the tang and left it to fully harden in a warm place for a few days.  As JB Weld sets very hard and can be filed etc when hard, any excess can be easily removed to give a flat surface under the dial.  The brass plate should not be too stiff and the dial part big enough to avoid the dial part peeling when bending to fix the dial. Obviously there must be room between the underside of the dial and the movement, for the repair to allow the dial to sit flat.  If its metal to metal then maybe superglue would work as well.
Hi   If the dial is made of brass then the same technique as soldering dial feet on may work using a new tab of thin brass soldered on using this method and reshaped. If you search the web for Dirk Fassbender he buildt a modified version of the one buildt by Wesley R Door (Horological Times) contributer.  Have alook at Dial Foot Soldering on the net..   Its like spot welding using solder but its so quickusing an arc to melt the solder the front of the dial is un harmed. Always useful to practise first on some old dials.  I have buildt one of these and it works on conventional dials.
Thanks for all responses. Your JB weld method seems like a good way to go canthus. I have used this on other non-watch items and it holds well. I have seen videos on soldering dial feet and I think I've seen the one you mentioned watchweasol but have not tried it. You can see by the picture (if I did it right) that the dial tab is brass so it should be the same as soldering dial feet.
Not sure JB weld will give you the flexibilty to bent the tab back into place but hey give it a try.  Three tabs should work since the dial reflector ring helps when the crystal is snapped in to place.
I too use an angle approach to lifting and bending the tabs.  So here is the tool I came up with to help with this.  No more than an exacto blade and the tip is notched soI can even used this tool to screw down a set lever screw.
One techinque I use on all Timex dials is to bend the tab back to 90 degrees from the dial before refitting to the movement.  This helps it fall into place better and not disrupt those darn day date detent srping that like to jump out of place.  and doe the 262 dial look like this one in blue?
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
