  • 0
Mazboy
Omega Spare Parts Reference Websites
Question
Hi all,
I have recently purchased an Omega Flightmaster 145.036 and want to replace the crystal with an original Omega crystal or a Sternkreuz part but cannot find any reference to the exact part codes i need, anyone know of a good reference website that has this information please?
Thanks in advance
Maz
Share this post
Link to post
3 answers to this question
  • 0
Hi Mazboy,
The best I've found is either CousinsUK.com (Go to watchparts>Branded>Omega>Case parts and search by Ref Number "145.036".
Now the second best has been http://cgi.julesborel.com/
Cousins tells me its a: Glass, Mineral, Omega TN5250
It appears to be a flat mineral crystal.
Some of the photos make it look like a domed crystal.
Either way genuine is around $60USD:
https://tmwatchco.com/product/new-genuine-omega-flightmaster-crystal-145-036/
I
wouldn't stuff around with an aftermarket on such a watch unless you are qualified to measure and size one up yourself.
Cheers
Alexei
Share this post
Link to post
  • 0
5 hours ago, AlexeiJ1 said:
Hi Mazboy,
I
Cheers
Alexei
Thanks Alexei, thats exactly what i need.
Share this post
Link to post
Answer this question...
Loading...
    • I figured it out. The point is to unscrew the crown and keep it in 0 position when pushing on the farthest/southern spot on the lever from the stem (close to the letter "p" in "push". Notice that the image above is when crown in position 2.
    • Chemical recation between markers and dial? Is it a plated dial? Send an email to Zenith and tell them that you are a long term customer but are dissapointed; can you help? etc.
    • The other calendar. A Raketa, technically I'm younger whilst wearing this A tricky one to take a pic of as the dial is quite reflective.
    • the tools used to push the plugs In/out of cylinders.
    • Depending where you are based it may be better to buy from a wholesaler such as Cousin here in the U.K, you say the clock is fitted with a pendulum so you will need a movement with a drive unit built in for the pendulum. As far as repair goes clock repairers would not waste time trying to they would just do a straight swap out of the movement, you need to identify the movement fitted cousins have Hermle and Seiko versions available: https://www.cousinsuk.com/product/strike-chime-with-pendulum-hermle https://www.cousinsuk.com/product/strike-chime-with-pendulum-seiko Also bare in mind that you would need one with the correct shaft size.
