Watch Case & Movement Engraving/Marking
Vladimir
Hi All,
Hope this message finds everyone well.
can anyone advise an affordable machine that can engrave/mark the back of a watch case or movement? I am starting my own brand, this is the only tool i am struggling to find at reasonable price.
your feedback will be highly appreciated.
any tool that can mar/engrave as per image attahced.....
regards,
Try Googling "CNC laser engraver", there are quite a lot of options including DIY but kit for engraving into metals is not likely to be cheap.
You might be better off out-sourcing the engraving to a company that specialises in that sort of thing. Probably cheaper that buying the kit to do it yourself unless you've got other uses for it.
On 11/21/2019 at 5:20 PM, Narcissus said:
Laser won’t be the best. As these parts are likely already plated/polished , the laser will just bounce off. (I’ve tried). You want a diamond-drag cnc engraver.
Maybe you'll want something like that
Especially likable .,. her almost indiscernibile Chinese accent.
