New member intro
Glasso
I hear it is polite to introduce yourself first so hello.  I'm Irish living in Dublin. I own only a few timepieces - the most known an Omega Seamaster automatic that I bought without knowing much about watches 15 or so years ago but which I don't wear all that much anymore and may sell on. besides that I would be more into clean aesthetics than brand per se currently. Favourite watches from looks point of view would be the clean and two-tone appearance of the IWC pilots watch.
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
