Pallet Warmer Project
Mark
Editing a video on the construction at the moment.
Need to reset the pallet stones in a vostok which was loaded up with too much shellac. Unfortunately my pallet warmer is missing - searched high and low - I suspect it's in pallet warmer heaven. So I made a new one. Hopefully this will be an interesting video for some. In fact - I made two. Will do a giveaway to a winner for one of them. Details will be announced in my next video which will show how I made these and the video after that will the Vostok restoration where I will demonstrate how they are used.
In the meantime - if anybody wants to build one themselves, I have attached the plans to this post. If you do make one then post pics :)
Pallet Warmer Plans.pdf
Nice one, thanks for the plans.... Strangely enough I was just looking for mine before reading this and found it.
Maybe your lost one is with Bagpuss?
Yikes - bagpuss. Now that's a blast from the past!
Sent from my SM-G950F using Tapatalk
  • Haha 2
32 minutes ago, watchweasol said:
Hi  Likewise Old H do you remenber Andy Pandy and Teddy , Watch with Mother,   not forgetting the Interlude....
Watch with Mother Monday
Andy Pandy Tuesdays
Rag Tag and Bobtail Wednesday
Bill and Benn Thursday
The Wooden Tops Friday.
A nice video Mark. What type of lathe are you using?
@oldhippy Sorry for late reply.
It's a mini bench lathe made by a company called Optimum. A relatively new addition to the workshop along with the mill.
1 hour ago, TheFixer said:
I have the copper plate so just need some brass.
Any chance of a picture with the wooden holder without the tool itself?
You can see it clearly in the video Mark uploaded, he shows the machining out process but it could be easily done with a chisel or by tacking sides onto a flat piece.
On 11/15/2019 at 10:59 PM, oldhippy said:
Thank's Mark for the reply and nice photo. That's a new one on me I'll look that one up.
Is it the Light Duty Lathe Optimum TU2004V 240v Variable Speed?
Absolutely - thats the one. So far I have had a few issues with it but noting major.
The gib in the compound slide was bent - easy fix but I need maybe add a couple more gib screws to make it more smooth and it came with an extraordinary amount of grit on the lead screws and ways. This is common with chinese lathes I think but didn't expect it with "German quality" - lesson learned :D
I would like to install a thrust bearing too, to minimise  backlash. But the parts I have made so far are quite accurate not bad for a light duty lathe. Not unhappy.
Thank you Mark that is very helpful.
  • 4 weeks later...
    • in general this shouldn't be any change. but in general questions like this it be nice to know the specifics of the watch in other words how was it performing before it was cased up and what is it doing now.
    • just as a reminder this watch is a Swatch group product. This will bring up a problem like spare parts and technical information. that I found some links to some information on when I talk about your watch and some of the technical and basically your watch is equivalent to 2834-2 for which I'm attaching the technical sheets. But equivalent does not mean exactly the same you want to do a search on the group for C07 as we discussed this watch before including the technical differences how it's supposed to be regulated and basically because it's watch group there is no parts availability. https://calibercorner.com/eta-caliber-c07-xxx/   https://www.chrono24.com/magazine/eta-movements-from-the-2824-2-to-the-powermatic-80-p_80840/ https://www.watchuseek.com/threads/h-10-movement-details.4636991/ eta CT_2834-2_FDE_481857_15.pdf
    • people be honest.... Swatch is evil for the watchmakers and repairers, BUT not everything in watches from Switzerland is from the Swatch-Group. As far as i know, Selitta got sacked by Swatch as a Movement-Assembler for them and they started to produce Movements in their own Name with slight Modifications. As far as i know, they sell Parts to the Market for their Movements. In most cases, if a ETA-Movement fails, it is a valid Option to replace it with a Selitta Movement, which i consider the Solution for this Mess with the Swatch-Group...... I have no Connection to anybody at Selitta, but being a Swiss-Guy, i still like to have Swiss-Made Watches, but not from the Swatch-Group.   ok ? regards, Ernst
    • Just one more greedy act by Swatch. They started a number of years ago here in the US..cutting off supplies to watchmakers that could build complications that many Swatch houses couldn't even touch. Old school masters who had gone through some of the most prestigious houses in the world. Otto Frei has some statements on their page about it. I tell all my customers to avoid new Swiss watches like the plague,..unless they just want an older one in their collection that still has some parts out on the market, or they have really deep pockets and don't mind waiting months and paying through the nose to get it back. Plenty of others to choose from..IE Seiko,..or other non-swiss brands Even a number of Chinese brands are catching up with the Swiss,..and I think that in time, their actions will be their downfall
    • Yes. If that's not what you are experiencing...start looking for something rubbing. A 1st guess is that one of the hands is rubbing against the hole in the center of the dial. Especially if you now have lower amplitude in face up/ face down positions.
