Pallet Warmer Project
Mark
Editing a video on the construction at the moment.
Need to reset the pallet stones in a vostok which was loaded up with too much shellac. Unfortunately my pallet warmer is missing - searched high and low - I suspect it's in pallet warmer heaven. So I made a new one. Hopefully this will be an interesting video for some. In fact - I made two. Will do a giveaway to a winner for one of them. Details will be announced in my next video which will show how I made these and the video after that will the Vostok restoration where I will demonstrate how they are used.
In the meantime - if anybody wants to build one themselves, I have attached the plans to this post. If you do make one then post pics :)
Pallet Warmer Plans.pdf
Nice one, thanks for the plans.... Strangely enough I was just looking for mine before reading this and found it.
Maybe your lost one is with Bagpuss?
Yikes - bagpuss. Now that's a blast from the past!
Sent from my SM-G950F using Tapatalk
  • Haha 2
32 minutes ago, watchweasol said:
Hi  Likewise Old H do you remenber Andy Pandy and Teddy , Watch with Mother,   not forgetting the Interlude....
Watch with Mother Monday
Andy Pandy Tuesdays
Rag Tag and Bobtail Wednesday
Bill and Benn Thursday
The Wooden Tops Friday.
A nice video Mark. What type of lathe are you using?
@oldhippy Sorry for late reply.
It's a mini bench lathe made by a company called Optimum. A relatively new addition to the workshop along with the mill.
1 hour ago, TheFixer said:
I have the copper plate so just need some brass.
Any chance of a picture with the wooden holder without the tool itself?
You can see it clearly in the video Mark uploaded, he shows the machining out process but it could be easily done with a chisel or by tacking sides onto a flat piece.
On 11/15/2019 at 10:59 PM, oldhippy said:
Thank's Mark for the reply and nice photo. That's a new one on me I'll look that one up.
Is it the Light Duty Lathe Optimum TU2004V 240v Variable Speed?
Absolutely - thats the one. So far I have had a few issues with it but noting major.
The gib in the compound slide was bent - easy fix but I need maybe add a couple more gib screws to make it more smooth and it came with an extraordinary amount of grit on the lead screws and ways. This is common with chinese lathes I think but didn't expect it with "German quality" - lesson learned :D
I would like to install a thrust bearing too, to minimise  backlash. But the parts I have made so far are quite accurate not bad for a light duty lathe. Not unhappy.
Thank you Mark that is very helpful.
  • 4 weeks later...
    • Dell fancy a challenge🤣   https://www.ebay.co.uk/itm/285785684626?itmmeta=01HT29WVJY21Q94C73GYHGBTFX&hash=item428a277a92:g:15YAAOSwNRVmBAUz&itmprp=enc%3AAQAJAAAA0DIe4QLQBW66rSyIMiyBuk8GY%2B86pQ%2BQnxGbcNq7egAGe5DIs9YMmiWJIbZtMSxwNJIiJxuojbq523IeUSBQ6pJEIQ0tfz2ChrBR03BksmKINyklg1IK4GAfAcYY9Hta9wVeSZSZN7ZCNAfZTgKs9c4%2BUIUZ3Qjc3QjUXDn2uPRo1FiYOEewMG5A26EXb%2BclBgrqtbOmM6P3bea%2F8ZImOAXNI1HtbmtMk84pIGoM6ISwaM1PKFuADtTFMccS5e3ZjndCbXYXHrW3CecsV0edw3M%3D|tkp%3ABk9SR8q588nQYw
    • A already know the size movement I have the problem is the dial a had purchased has a dimension 20.6mm wide a want to find a watch case that going to fit the dial perfectly
    • Hi.  I would like to take issue here regarding battery driven , watches, clocks,etc. I will and do repair these clocks in fact I have sever al in my collection as well as the regular mechanical ones. I have one on my mantle piece over 60 years old tha belonged to my wife’s Aunt,  long gone Iam afraid and it has been cleaned etc and never missed a beat and is accurate. Every one has their preduices as regards Electrical /electronic Horology but I regard it as part of the progress time line of the art of Horology and to be treated as such. Like Darwin’s theory of evolution it evolved.  Two cavemen knocking rocks together and a shard broke off , looking at it he worked out if it was stuck on the end of a stick he would have a spear. Likewise his pal seeing what he was up to picked up a piece  and did the same, now that’s evolution. Some clockmaker decided to build a clock that ran with a battery and no spring to wind up and break, progress and both the mechanical and battery driven clocks evolved, the battery ones got better to the point that if it broke you changed the complete unit. Likewise watches did the same but both can be repaired by people who approach Horology with an open mind without preduice.  We all have our likes and dislikes bu I for one would never dismiss any technology because I don’t like it.   The mobile phone is a good example of modern technology at work as is the automotive industry. There buttons and switches in my car I don’t use because to me they are not nesessary but I still drive the car.
    • I haven't gone through all the reading of what it might be or not. The first thing I would do if nothing obvious stands out is replace the mainspring, you have to start at the source of the power. Nine times out of ten that is the problem.
    • Haha. You're just in a wicked mood today John 😅
