Tools you can't live without?
FLwatchguy73
Good morning folks. If you had to recommend 2 budget conscious (under $300) tools to a hobbyist watchmaker what would they be? I already have the bare minimum hand tools necessary to do the work. There are so many tools I'm sure I could find useful occasionally, but what would be 2 tools you would be lost without, other than screwdrivers, tweezers, movement holders, timegrapher, etc. Thank you.
     save the 300 bucks  and search for used tools.  a book by de Carles at the library might be good.   vin
Above lathes are recommended but the OP clearly stated he's asking for tools under $300. And he mentioned ones excluding a timegrapher, which I suppose he already have. So I can recommend budget good opening tools as discussed below
And then a pressure tester, which is around $150 on AliX.
Its very sad but as you get older your fingers aint the same...I don't think I could do without a selection of those grab claw crown winders which keep my hand wind watches going especially when the crown gets a little worn. Perhaps I should just stick to automatic watches
I have definitely encountered the need for a good opener. I was servicing a vintage Seiko 7002 diver for a friend and I nearly couldn't get the back open. Are there tools that make opening snap back cases easier? Knife blades are terrifying to use but occasionally that's all that will work. Thank you for the suggestion.
    • this is something I've never quite understood about the some of the Swiss companies. In 1957 Omega was using 9010 for the keyless parts with epilam. there's been a slow migration towards using heavier lubrication's but still typically oils and epilam to keep them in place. When it seems like 9504 works so much better.
    • OK, welcome in the world of alarm clocks... I guess the 4th wheel is dished because it is from another movement. If it was not dishet, then it would not mesh with the pinion of the escape wheel, am I right? The marks of wear on the 4th wheel pinion doesn't corespond to the 3th wheel table position, at list this is what i see on the picts. Calculating the rate is easy - there is a formula - BR = T2 x T3 x T4 x T5 x 2 /(P3 x P4 x P5) where T2 - T5 are the counts of the teeth of the wheels tables, and P3 - P5 are the counts of the pinion leaves. Vibrating the balance is easy - grasp for the hairspring where it should stay in the regulator with tweasers, let the balance hang on the hairspring while the downside staff tip rests on glass surface. Then make the balance oscillate and use timer to measure the time for let say 50 oscillations, or count the oscillations for let say 30 seconds. You must do the free oscillations test to check the balance staff tips and the cone cup bearings for wear. This kind of staffs wear and need resharpening to restore the normal function of the balance.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
