Mobile Watch Repair Kit
Yes please we'd love to see more video's for beginner on how to start/progrss. It would be very encouraging and inspiring.
I'm told... "If you think collecting watch is an expensive hobby, try watch repairs/making"
I will do this video. Thanks for your comment. I’m sure there will be a lot of pros out there that will provide positive criticism as well:)
Yes, encouragement,  that is the word.
 Mankind is the kind of creature, that if we believe we can accomplish , we eventually will.
Thank you for sharing your attitude.
God bless.
Thanks for the comment. One can do absolutely anything with passion and some aptitude.
