Removal of Date Complication
LiamB
This might sound like an odd question, but would it be possible to remove the date function from an eta movement? I am working on a project watch I am designing and building and I can’t source myself a movement with the desired specs that doesn’t have a date function.
Short answer is yes. You can remove the components that make up the date complication, however, you can't remove the stem position. In other words, there will still be a second position when you pull the crown out where you would normally adjust the date, it just won't turn anything.
Edited by mousekar
Absolutely yes, as above though there'll still be the intermediate position but as you won't gain any extra space you could simply leave the calendar works in place and put the dial over the top of it.
Edited by m1ks
LiamB,
Not sure what project you're doing but sometimes watches without day/dates have different dimensions.
So if you are trying to fit a no-date movement in a watch case which previously held one with day/date you may find the stem hole in the case and movement do not line up.
If you are in contact with Sellita they should be able to provide you with the dimensions and you can compare that with the movement you're replacing.
Good luck!
Anilv
    • So here is the new base (v 2.1), I made it so that the base will fit over and swallow the stump of the hand pusher tool (or at least my clone of the tool), I also reduced the OD of the bottom skirt a little as it looked/felt a little large, here are a few pictures and the fake .pdf file which you need to convert to .zip once downloaded.   The cut-out seen on the below image on the bottom of the base should swallow the OD (40 mm, +0.1 mm tolerance) of the stump and the height of the stump 9.5mm (measured to 9.1mm, but rounded to 9.5mm) - let me know if this works for your tool.   Note, I think you may need to print supports for the new internal shelf created? Modular Movement Holder.pdf
    • Have read of the Tech Sheet attached on the balance section page 12. It may be bent but until you reposition it back in the regulator pins you'll never know. Cheers CJ 4R35B_4R36A.pdf
    • Aloha All, My Seiko 4R35B movement stopped working today. Upon closer inspection, it looks like the balance spring came out of the regulator pin. This is my first time working on a balance. Any advice on how to get this spring repositioned (back to normal)? I'm pretty sure that while adjusting the beat error on this movement, I must have turned the stud (I didn't even know they turned), and the spring eventually fell out.  Will the spring go back to even spacing when it's back in the pin, or does it look bent? Thanks, Frank
    • Good job, that band matches the watch perfectly.
