Emporio Armani ar-1922 repair
Furqan
Hello Everyone.
I need some help with repairing my Emporio Armani ar-1922.
I've watched some videos on YouTube but none of them resemble the movement of this particular watch.
My first problem is removing the stem/crown. I cannot see anything which looks like it will release the stem and I don't want to poke around inside it any more for fear of creating any damage.
Any help will be much appreciated.
Thanks.
This movement looks a lot like a TMI (Seiko) movement. If I'm right then there should be a little notch to press in the setting lever, around the red dot in the image, with the crown in the normal possition. I can't see it 'cause the image is quite dark there, but you can look for it.
Hi  Underneath the balance there should be a logo and a number this is the make and caliber of the movement, In some cases its engraved in the plate this we need for posative Identification.  If you fail to locate the release using acc's method pull out the stem and look for a small lever appearing near the stem,  If this occurs then press down on the lever and remove stem. Without clear photos and or data its all guess work.  Armani dont make watches they just put their name on it they could be Seiko, ETA, Miyota or even chinese movements fitted.
I'm fairly certain this is a Chinese HZ2189G - Otto Freil do them for about $33.00
.. a bunch of ebay sellers also have them
https://www.ebay.co.uk/sch/i.html?_odkw=skeleton+2198&_sop=15&_osacat=0&_from=R40&_trksid=m570.l1313&_nkw=Automatic+Movement+For+2189&_sacat=0
The stem release on some of these Chinese movements is a bit of a movable feast, because despite being based on the Chinese Standard movement, they incorporate a few local tweaks depending on the individual manufacturer.
I don't have one to check, but I suspect you press on one of the two areas I have indicated below with your tweezers while gently pulling the crown. My bet is on the larger of the two areas I have indicated. Use gentle pressure, as you don't want to damage anything if my hunch is wrong.
Edited by AndyHull
Correct. Nitpick: the Seiko brand for OEMs is named SII (Seiko Instruments International) and accordingly the mov'ts are stamped. TMI (Time Modules International) is the name of their Hong Kong subsidiary marketing these to most of the world, in practice the two are the same thing.
  • Similar Content
    • I've remained silent on this thread, and at the risk of upsetting everyone, the thing that worries me the most the the apparent absence of Mark. The moderators do a great job and the members also pitch in, and the site seems to run itself, but it is a concern for the future of this forum when the owner is absent for all intents and purposes. Like many of the comments above I would hate to log in one day and things be closed down as I rely on this site for ideas and knowledge and also cheer me up. maybe the Moderators could reach out to him, assuming he does not read this thread, and express our concerns and let us know the plans going forward? some kind of WRT ark
    • That was the exact reason for me starting this thread watchie. Still we haven't worked out how the regulars are going to hook up if it goes tits up. I honestly think something should be arranged to stay in contact, we all help each other so much.
    • Yeah ive watched that a few times before,  i couldnt find my old school dividers to scribe it up 😅 Yep thats the guy i bought a roll from . Thanks Nicklesilver that answers that perfectly and more or less what i thought an experiment over time would prove . The jumper arm is quite thick along its length, i left it that way intentionally, i thought the original was probably very thin, i didnt see that it was already missing. Setting isn't particularly stiff as such just positive, i still need to take it out and polish where it mates with the stem release.
    • Yes, "Sold out" is difficult to understand. There doesn't seem to be a lot going on. It's been nine months since any new video was published on the Watch Repair Channel. The Level 4 course on watchfix.com has been in progress for what feels like forever (several years!?). Maybe Mark's enterprises aren't doing well or perhaps already so profitable there's nothing much to motivate him for more material. Or, perhaps these days he's more into crochet. The real reason is probably something entirely different but it would be nice/interesting to know. I don't mean to sound gloomy or pessimistic, but I wouldn't be surprised to be met by an HTTP 404. Every day feels like a gift. Speaking of watchfix.com I've been postponing the "Level 5: Servicing Chronograph Watches" course for a very, very long time. Anyway, I just enrolled on it so it's going to be very interesting to see the videos. I must say, IMO there's nothing really that can compete with Mark's courses when it comes to presentation and video quality. It's simply world-class and makes me associate with some really expensive BBC productions.
    • Steel has some funny properties, or at least counterintuitive. The modulus of elasticity is effectively (not exactly, but close enough) the same for steel that is annealed and hardened. What changes is the point of plastic deformation* . If the movement of your spring doesn't pass that, it should work fine. It looks a little thick, I would thin it a bit maybe from the main body out about halfway, maybe 10-20% thinner (not in thickness, along its form). But if it works it works!   *So- if you have two bars of the same steel, one annealed, one at 600 Vickers (general hardness watch arbors might be), clamp them to a table so the same length is hanging out, and put a weight on the ends, they will bend the same amount. But if you continue to add weight, then remove it, at a point the annealed bar won't return to its original straightness. That's the point of plastic deformation. But up to that point, as springs, they are the same. However- their wear characteristics will be very very different. And getting the hardened bar past its point of plastic deformation takes a lot more effort.
