Hi, Thanks for letting me in.
Seahorse
Hi, I've just signed up, I've loved watches for years, but I've only just started collecting and working on them. I've got a few old Accurist and Seikos amongst a others and I'm looking for advice on cleaning and refurbishing mechanical watches.
I'm a mechanical engineer,  but spend my time working on marine diesels, so watches are at the other end of the scale. It fascinates me how they get so many small parts working in harmony in such a tiny case.
I'll try and post some pictures soon.
     welcome to the forum !   as an engineer,   you know the tech. manual is most imporant !  HA !   BUT,  watch tinkering is  better than working on "an old lister diesel"  cramed into the laserette of a racing sloop !     cheers,   vin
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
    • I did not. I thought about it, but I had cleaned it in my ultrasonic, and the tech sheet shows lubricating it in place already assembled, so I figured discretion was the better part of valor. Although since I have to depth the jewels anyway, maybe I pull the pinion off to rule it out 100% as part of the problem. Do you know if there's a safe way to do it? I don't want to use a puller because it would push down on the plane of the wheel, and that seems like a Bad Idea. I thought about using a roller table remover, but I don't think I have a hole stake pointy enough to push it down.
