French clock troubles
clockboy
I was asked by a friend to look at the French clock he had purchased from eBay. He could not get it to run. Initially I thought it was just out of beat BUT I found the suspension spring was a complete bodge the pendulum had been packed with a cardboard shim, the hour hand was touching the numerals and the case was loose. HOWEVER although I have got it running it runs for 5/6 hours then just stops. Listening to the beat using my stethoscope it is in beat then slightly out of beat then goes back into beat. I presume this is a damaged escape wheel. I have recommended he sends it back.
1513447183_French2.jpg.e81fe717306cb0652f111ecae79737e2.jpg1887076681_French1.jpg.620d1784a28332c71a84149d58602e98.jpg
That description is what I would expect from the teeth of the escape wheel, it could also be worn pallets, worn holes escape wheel or pallets or both. Sending it back is the right thing providing if the seller said it was going and keeping good time. Ebay have a guarantee these days so the person will have a full refund.
Pity the seller didn't spend time with the movement instead of concentrating on the case. No good having a nice looking case if the insides don't work.
Thats what I suspect. I did inspect the movement and it looks dirty but the bushings look good. I did polish the pallet and although some wear I have seen a lot worse and the clock has still ran. I could not see any obvious bent teeth on the escapement. He has asked me to try and fix it so a complete strip down and inspection will be done (if time). 30 days to get it up and running or returned is the schedule.
Hi  I agree with Old H  sounds like wear and tear on the escapement, on some clocks the pallet anchor can be moved along the arbour slightly to work on a new face, that depends on the type of pallet. wear on the escape wheel and pallet accumulativly will cause all sorts of running problem s such as you describe. Like you I have seen some clock pallets grooved and still running although they were mostly Ansonia American ones french clocks are a bit more delicate, Just mind the pivots they are glass hard and dont take kindly to rough handling.
Agree, tip never try to re-pivot a small French clock's pivot. The metal is so hard it's impossible.
This evening I investigated further and the escape wheel tips are thin with some beveled over. Not surprising as this movement was from 1900 ie getting on for 120 year old. I have straightened the offending tips and polished gently with a polishing paste and rinsed in white sprit and finished off with methylate sprits. It now looks good and a quick test all seems to be working. I will put the movement on my test rig tomorrow and hopefully all is OK. If not a donor movement might be needed.
As said above about the escapement teeth may be the issue, however if it still goes out of beat after you fixed them then it maybe the escapement pivot or the anchor pivot or both that have just enough play to jump every so often. They are so thin it is hard to see and it does not take much ware to stop the clock, I would give them a very close look before getting another movement.
    • Welcome my friend.
    • Been there. Worn that Tshirt.  'ping'. Hands and knees. Nothing. Nada. 20 minutes? Ha! I found it 7 month later. How? Well, after advice from a member, I invested in a £4 UV light torch.  Hands and knees looking for a 'ping' from a Sekonda, found them both within 30 seconds. UV makes the jewel shine. easy peasy. Could have taken longer. Just lucky on the location of the search. Hope this helps.
    • Thanks Dell. I thought about silver soldering. Have never done it but would like to give it a go. Do you think to put flux on the butted joint then run the solder in or to maybe brace it with a piece of scrap spring steel?
    • Never and others. Yes, like you I do spend a fair amount of time reading the contents of this forum. I find it better that any other. Clear, lucid, no Prima Donas, and most of all an easy access without adverts. All thanks to Mark. God bless you mate. You give so much to many of us. What if? No Mark? Hypothetically. A forum. I did run a forum for a few years. Really enjoyed it, but became so engrossed that it did affect my health. I gave to to others to run. Not been back. It was very successful and rivalled a number of large paying sites. No adverts, no others but me. I did ask and listen to members comments and it worked well.    Costs Having a domain name, £10 annually.  Register the site with a forum company, free. Build the site using the forum company guide lines, free. It looked and ran almost the same a Mark's. All the same facilities. The cost was only £5 per month, but counted visits (views). If I recall, it was that price for 5,000 views. Each extra 5,000 views increased the price by £2 per month. Success was my own personal undoing. From £5 per month initially, it rose to £60 a month and looked like increasing. This was 10 years ago. I could not afford that, and asked it anyone would like to take over and someone did. I would assume that this is the price that Mark is funding for us all. His return is our continued comments on the internet about his course, and the fact that many of the big names on YouTube mention him as their Tutor. Those of us who have done, and are still using, his course, benefit. In comparison to other courses, I can't believe how cheap it is, and the value is exceptional. It is the structure that gives the value. Long may Mark reign. Ross
    • Hi all, total newbie to watchmaking and I've had a bit of a mishap. Just completing level 2 and was doing ok, but I was just on the last part of the reassembly of my ST3620 when the balance end stone shot across the room, just as I was trying to see if I had put the correct amount of oil between it and the balance end, aarrrgh! Been on my hands and knees combing the carpet for 20mins looking for it but to no avail. Does anybody know where I can get a replacement from and what to look for please?? Thanks.
