Tag Heuer link watch!
bosstaki
The red hand is the chronograph minute counter, there is no minute sub dial on these watches, top right sub dial 1/10th of a second bottom middle sub dial constant seconds, top left sub dial  hour counter.
Thanks for the info mate! Do you know how to rest the red pointer please!
The red pointer should reset when the chronograph is reset, is the large white hand moving ? if so the chronograph is running, press the top button followed by the bottom button and all the hands should reset to zero, if not the hands have gone out of sync, these can be reset, unscrew the watch crown pull it all the way out, then press both the top and bottom chronograph buttons at the same time the chronograph seconds hand will do a complete revolution that indicates the watch is in hand reset mode pressing the top button will advance the large seconds hand one second at a time, pressing the bottom button will move the reset to the next sub dial hand, pressing the top button will then advance that hand one index at a time repeat till all hands are in their relative zero positions.
If you get stuck their are plenty of youtube videos on the subject of resetting quartz chronographs.
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
    • nevenbekriev- You nailed it with your description of me and my reaction when the clock started ticking again. I am a newbie.  I love the sound and idea of mechanical clocks but the idea of owning one and trying to keep them running has never appealed to me. My wife bought this one and an antique German wall clock.  When I looked into having someone repair them for me, the universal response was "it's really expensive to work on them, you should just replace the movement". So, I had nothing to lose, I started researching them and opened them up. The wife is happy because she hears the sound of the clocks again. But I have gone down the "accuracy" rabbit hole. In the vertical position, the balance wheel was not floating. It was sitting on the bottom of the frame. I adjusted the lower spring collet and got it floating. It easily passed the 270 degree 3 to 5 minute oscillation test. It took 8 minutes for the wheel to completely stop moving.  I put it the unit back in the movement and checked the safety pin. It does not touch the safety roller anywhere in +/-270 degrees rotation from neutral position. But the amplitude of the rotation with the spring fully wound is weak based on what you are saying. It rotates +/-90 degrees from the neutral position.  No, I did not take the movement completely apart.  That seemed way outside my skill set at the time. There is a reason I became an electrical engineer and not a mechanical engineer. I am much more comfortable with moving electrons than tiny moving metal parts. Will I do it in the long run? Anything can happen. I don't seem to be able to let it go.
    • Isn't that the same guy who told Zelenskyy to escalate the war with Russia/Putin when they already had a peace deal? 2 years later and we have half a million young Ukranian boys dead. He doesn't seem very clever...
    • Thanks guys.  quick question. For automatic movement, particularly this one. can I power down the main spring by pushing this rachet down?  i've gotten pretty used to SW210 and powering down a manual movement. But so far i've only been waiting for the auto movement to run out of juice before opening the case.
