clock i got today part 4
luiazazrambo
8 Day French Strike on a bell. It has count wheel striking. Original half moon hands. I don't think its the original pendulum, it certainly isn't the normal type I would expect to see. If you remove the bell you should see some numbers, one of the set of numbers on the back plate should match the numbers on the pendulum. That is the way of telling if the pendulum is original, The other set of numbers tells you the length of the pendulum in French measurement, I can't remember which one. White enamel dial, I see a touch of chipping around the key hole on the time side. Fine regulating can be made by the adjustment jut above the 12.
That back plate number is the movements serial, the pendulum should have the same on it, I have never seen a hexagon shape pendulum before on a French clock. Someone has made a mess of bending that crutch to try and set it in beat. The oil sink on the large wheel loos a bit suspect going by the photo. When its all cleaned up movement and case you will have a nice looking clock.
Hi You might find this interesting reading if you are interested in french clocks.  One thing to remember with french clocks the pivots are glass hard and brittle so when dismantling ,cleaning and rebuilding be very carefull and dont use force when putting the back plate on and be gentle when aligning the pivots and holes and you will be ok.
dating french clocks.pdf
    • 🤔 leaving the EU meant that UK was no longer part of the convention and have already been turned down an independent reapplication. I'm pretty sure courts have to be held in Switzerland in this case. There will be a lot more watches stashed away in draws  tbh, folk wont be able to afford to maintain them. Cheap watches will be bought and top end watches by folk with plenty of cash that can pay for service and repair. The expensive once in a lifetime gifts and everything else inbetween will be at the forgotton when they stop working. I know i was being a numpty, get used to it 😄 Anybody that knows will boycott them, but besides repairers who will know. Nope will never buy one, i made that decision as soon as i learnt about this.
    • although not in this case.  It was the Lugano Convention and its deficiencies that allowed a Swiss court decision in the first place.  This isnt really a Brexit issue at all.  A decision that affects both the EU and the UK should never have been heard in Switzerland. I bet the authorised service centres in the UK are pretty pleased.  It's a massive shame, though; I believe watch owners should be able to choose to have their watch serviced by whoever they trust.
    • Hi guys I think that old hippy is correct, it opens the gates for china to manufacture aftermarket spare parts. considering that they already do work on behalf of the Swiss I guess this decision gives the a little more legitimacy to tool up and I am sure they will take advantage of the situation either with or without the blessing of the Swiss watch industry  Having read about the protectionist machinations of the Swiss in the history of Europe they were the only ones to get fat at everybody else’s expense. I think the outcome could have been guessed at but ,  fair play to Cousins UK for standing up to them.  Now the question,  will everybody boycott Swiss watches and Swatch, no way they will still fill their coffers.  Me I stick with the Japanese once renowned for cheap shitty watches who came good through industrial effort and don’t for get the Russians that most dismiss as low grade crap. Wouldn’t buy a swatch product ever how about you all.? a
    • Hold the crown when in winding position, move the click away from the crown wheel, and then while holding the crown let it slowly unwind. I recollect that you must remove the automatic device bridge first, but maybe I'm wrong. You can first try without removing the automatic device bridge.
