clock i got today part 2
luiazazrambo
Where is the serial number? It does not seem to work by the way. I am going to replace the battery and see if the coil is not broken with an ohm meter. I spent more than 4 hours on the road to pick that lathe up, could not wait for daylight to take the pictures. I am excited. :)
    • Is the Roamer not a split stem? I'm confused on your how your case is put together. If it is a front loader where is it you are putting the case screws? I love me some Roamer, do you have any photos?
    • Oh nice. I have a similar wedge style stump for my staking tool, so I'll give that a shot. Thanks!
    • Thank you all for the replies!  Very informative! True enough, the Gamsol took some time to evaporate and does leave a residue. So not all naphtha are created equal!  Need to find alternatives then. i was able to try Hexane recommended by Alex and it seems great.  I wonder what the cons are?
