Case tube removal
no-time
Now that I've introduced myself :) I'm a beginner.
The screw-down crown is not screwing, as far as I can tell the tube is not threaded.
1. How do I remove the tube?
2. Once the tube is removed I have to check that it is the tube that's faulty and not the crown?
3. I have to measure the tubes width and length to find the replacement tube?
Thanks. 5981e670f56eccf9e76c7785f8757db5.jpg4b7b3a102fdc6c89d4e3bcc51303aa4f.jpg
Sent from my SM-G900F using Tapatalk
Welcome to the forum.  From what I can see (in Close up) the inside of the tube carries a thread, Therefore the the crown tube has a thread and screws down on to the tube. Either one could be stripped so carefully check both out before attemping to remove the tube. Remove the crown from the stem and inspect the crown tube
When I remove the crown from the stem, where do I hold the stem from?
Say 0 is near the crown and 10 is the end of the stem the opposite side, where shall I grip the stem?
My pliers aren't very good, i need to buy a decent pair from Cousins UK.
There is a flat section of the stem usually, which is nearer "10". From "10", there is the tip, the square, and then the notch.... the flat section should be next, before the threading starts. Grip here with a pin vice.
For the pendant tube, punch it out with a punch which has a size which is just marginally under the width of the tube. Use a lightweight hammer and keep tapping.
Test old crown with new pendant tube before fitting.
    • Glue a nut to the barrel lid, insert a bolt, pull, disolve the glue.  Maybe someone will have a better answer.
    • The stress is the force (on the spring) x distance. The maximum stress is at the bottom, and decreases up the arm. That's why they always break at the bottom. I used a round file, then something like 2000 grit to finish. I gave the rest of the arm a quick polish - no need for a perfect finish. Just make sure there are no 'notches' left from cutting/filing. The notches act like the perforations in your toilet paper 🤣
    • It's probably a cardinal rule for watch repair to never get distracted while at the bench. Yesterday, after finishing a tricky mainspring winding/barrel insertion (I didn't have a winder and arbor that fit very well) I mentally shifted down a gear once that hurdle was passed. There were other things going on in the room as I put the barrel and cover into the barrel closer and pressed to get that satisfying snap. But when I took it out I realized I never placed the arbor.  When opening a barrel, we are relying on the arbor to transfer a concentrically-distributed force right where it is needed at the internal center of the lid. However, when that isn't present it's difficult to apply pressure or get leverage considering the recessed position of the lid, the small holes in the barrel and the presence of the mainspring coils. It was a beat-up practice movement so I didn't take a lot of time to think it over and I pushed it out using a short right-angle dental probe placed in from the bottom, but that did leave a bit of a scratch and crease in the thin lid. I had also thought about pulling it using a course-threaded screw with a minor thread diameter smaller than the lid hole and a major diameter larger, but that may have done some damage as well.  Thinking about how this might have been handled had it been a more valuable movement, is there a method using watchmaking or other tools that should extract the lid with the least damage?
    • 🤔 what happens if lubrication is placed directly on top of epilame ? Making a small groove so the lubrication doesn't spread across the component but what if when lubing a little overspills and sits on the epilame .
    • Why just the bottom mike ? Is it worth polishing the whole arm ?
